shock mounts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2008, 01:46 AM   #1
bk87
Default shock mounts
Just wondering what size plate you guys like using for coilover shock mounts and what you use for mounts for links. Thanks for any info.
bk87 is offline   Reply With Quote
Old August 10th, 2008, 02:08 AM   #2
Bones
Bones's Avatar
1/4"
shock mounts axle end
link mounts
http://www.ballisticfabrication.com/...ts_c_24-1.html
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old November 1st, 2009, 05:21 PM   #3
tony_gapczynski
tony_gapczynski's Avatar
i made some for my truck out of 1/4 turned out good. ill post pictures after i get them welded into place.
tony_gapczynski is offline   Reply With Quote
Old November 1st, 2009, 09:46 PM   #4
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
3/16 is plenty
Old November 1st, 2009, 10:55 PM   #5
Yota Bill
its more about how they are designed then the thickness of the steel...a poorly designed mount made out of 1/4 isnt going to be stronger then a well designed mount made out of 3/16
Old November 2nd, 2009, 07:55 AM   #6
95geo
newbie
95geo's Avatar
I usually do 1/4" and more than just 2 flat tabs if they will be taking the hard hits when the shocks bottom out or if there will be bump stops to take the hits then 3/16" is usually enough.
Page generated in 1.44892 seconds with 41 queries
