I'm looking for a resistive based pressure sensor that will work somewhere in the range of 0-120 psi. My PSI manifold has 1/4" NPT fittings, but I should be able to make anything work.
THis is going to be working with my custom gauges for the Jeep. Its basically nothing more than a 5V voltage divider.
Yes you can, but you would probably be better off getting a hobbs switch with settings for what you are looking for. Any HD truck parts supplier has them and should be able to help you.
I used a pressure switch from a hardware store and rigged it up to my ac compressor. Only had to supply power and the air. It would shut off the compressor at like 125 psi I think. I've since sold that XJ though.
He doesn't want a switch, though. He wants something that provides a varying resistance, so that he can convert that into a voltage and read out on his digital gage screen what his tank pressure is.
oh ok. I guess I misunderstood. Sounds kind of complicated. just thread in a dial gauge from a compressor...
Related Threads
4.2M posts
30.9K members
Since 2005
