I am thinking about selling the last of my projects but not in any big hurry to sell it.
Started life as your average yj. Frame was replaced with an aftermarket box tube one.
The body is extremely solid rear has been comp cut. Only needs very minor finish work if you really want it to look great. No front fenders. Clean windshield frame no glass
suspension
rear is 4 linked with the sway away 2.5 series 18" race runner coilovers with remote reservoirs and dual rate spring
front is 3 linked with track bar and the same sway away 2.5 series race runner coil overs with remote reservoirs and dual rate springs
all good heim joint not the cheap tsc ones
all mounts are ruff stuff
have nitrogen regulator to fill shocks
misc
has full aftermarket cage tied to the rear shock mounts all just tached in place needs finish welded. Also integrated winch mount plate on front as well as stinger all welding on frame and rear suspension is done the mounts on the front axle are tacked in place but will need finish weld and the cage needs finish weld. FAME REAR AXLE AND REAR SUSPENSION HAS ALL BEEN COATED WITH BEDLINER
axles
rear is a 14 bolt ff with disk brake conversion comes with a detroit locker and 5.13 gears installed heavy duty 3/8 plate diff cover
front is a dana 60 with a power locker currently has 4.56 gears comes with 5.13 gears new in box just need installed. has new lockouts. also has artec full hydro skid plate and ram mount tacked in place
steering
it comes with a rebuilt 2x8 double ended ram 2 different oribital valves a column to direct mount oribital and a steering wheel
drivetrain
set up for sbc no motor included. comes with a fresh rebuilt turbo 350 tranny. Transfercase was switched to a np205 comes with a clocking ring to make it flat belly. HAVE A SET OF CERAMIC COATED HEADERS AND DOWN PIPES, ALUMINUM RADIATOR, PAIR OF NEW FLOWMASTER, RCI FUEL CELL THE ONE DESIGNED TO MOUNT BEGIND REAR SEAT
has rear seat but no front seats
comes with tons of extra parts and most parts needed to finish i am sure i am forgetting things
all the hard work is done
DOES NOT COME WITH ANY WHEELS OR TIRES
has a clear title
i would sell for 4500 FIRM way more than that in parts most parts are new
LOTS OF WORK DONE SINCE PICTURES WHERE TAKEN ONLY LISTING BECAUSE I NEED A NEW DD PRICE IS TAKE IT OR LEAVE IT
MAY PART OUT GAUGING INTEREST AND TAKING OFERS
suspension
misc
axles
steering
drivetrain
has a clear title
