2500hd 6.0 wheeling rig build - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2017, 02:25 PM   #161
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Looks good!
Sent from my XT1254 using Tapatalk
Woodyjiw is offline   Reply With Quote
Old June 20th, 2017, 04:26 AM   #162
siettas81
siettas81's Avatar
thank you going to start on bed cage soon so i can get shocks mounted up and have her sitting on her own weight again !
siettas81 is offline   Reply With Quote
Old June 20th, 2017, 04:28 AM   #163
You thinking about tying the top of that truss into the top bolts of your diff cover to negate peel on the top plate?
Looks good, you're going to have a ton of travel available if you want it!
Old June 20th, 2017, 09:42 AM   #164
siettas81
siettas81's Avatar
yes i have a plate for it and a pinon bash guard just haven't put them on yet. need to modify it a little bit still after i gear the rear end one of these days i will install them also
Old June 23rd, 2017, 06:03 AM   #165
siettas81
siettas81's Avatar
going to start bed cage / shock mounts this weekend should be sitting on her own weight next week
Old June 23rd, 2017, 06:28 AM   #166
k5jess
k5jess's Avatar
How come you didn't go a full width truss?
k5jess is offline   Reply With Quote
Old June 24th, 2017, 07:30 AM   #167
siettas81
siettas81's Avatar
i was going to but ordered wrong one and didn't feel like messing with sending it back so just used it
Old June 24th, 2017, 01:59 PM   #168
what's the vertical separation at the frame end and axle end?
Surviving Project Car Hell - We have all been there
JohnnyJ is online now   Reply With Quote
Old June 26th, 2017, 04:15 AM   #169
siettas81
siettas81's Avatar
front is set at 4.25 right now, going to move it up the top hole witch is 5.5, but i know its more at axle end, the front link mounts are the dual adjustable mount from ruff stuff, but i do not care for the upper mount part of it i might make new ones for the upper links and go higher and shorter link we will see. it cycles decent but could be better i will fine tune it in ones i get shocks mounted and it siting on its own weight
Page generated in 0.25073 seconds with 53 queries
