Do-all ex-welding truck - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2017, 06:04 AM   #141
k5jess
k5jess's Avatar
Looking good dude.
k5jess is offline   Reply With Quote
Old June 13th, 2017, 08:35 PM   #142
Do-All Ex Welding Truck (98 Chevy 3500)
Originally Posted by Gunsworth View Post
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old June 14th, 2017, 07:32 AM   #143
so.. what is it?
Surviving Project Car Hell - We have all been there
JohnnyJ is online now   Reply With Quote
Old June 14th, 2017, 07:37 AM   #144
Originally Posted by JohnnyJ View Post
so.. what is it?
1 ton grade slider boxes, or at least the start of them
Old June 14th, 2017, 07:56 AM   #145
k5jess
k5jess's Avatar
Why not traditional shackles?
Old June 14th, 2017, 08:20 AM   #146
#becauseshoptruck
After doing a lot of reading and not wanting to pay for the shackle flip, most if the sas kits require 52" springs, which package hard in a low lift application. I am hoping this packages nicer, and it should have plenty of beef.
Those are .75x1x2 blocks of ampco bronze
Old June 14th, 2017, 05:40 PM   #147
I made my own slider boxes too, going on the rear of my trail truck, but they're way beefier than the Lii ones you can buy. I'm using hmwv i think lol. The bronze is a great idea though. I'm gonna see how long the plastic holds up and go that route if needed. Thanks!
This truck is cool as shit too! The sas is going to put the icing on the cake for sure!
Old June 14th, 2017, 06:29 PM   #148
We had this bronze lying around at work, soooooo
Glad to see others are using the slider boxes too, I'm excited to get some front suspension flex as well
Old June 14th, 2017, 08:13 PM   #149
busyfixin
Balls Deep
busyfixin's Avatar
It's always a wise idea to install some Ford parts in a rig, especially a Chevy, they need all the help they can get!
I'm pretty sure my next front suspension job will use slider boxes too.
busyfixin is online now   Reply With Quote
Old June 14th, 2017, 08:35 PM   #150
Almost all of my builds have had ford parts in it. 8.8 in the xj, driveshaft in the 77 chevy, ford d60 in this truck, and currently planning mustang hydroboost in the kernel. Rear end of the other 46 willys will probably be a ford axle as well.
Old June 15th, 2017, 05:42 AM   #151
BigBlockTony
BigBlockTony's Avatar
Now if only we can get you to go small block power or idi (i guess that really isn't Ford)
BigBlockTony is offline   Reply With Quote
Old June 15th, 2017, 06:35 AM   #152
It's got small block power
Old June 15th, 2017, 03:43 PM   #153
BigBlockTony
It's got small cock power
Fixed
Old June 15th, 2017, 08:25 PM   #154
Old June 17th, 2017, 11:17 AM   #155
Got a wedding today, so won't get much more done. Made some beefy front spring hangers. Needed the 3.5" id
Old June 19th, 2017, 01:52 PM   #156
Old June 21st, 2017, 06:06 PM   #157
Old June 21st, 2017, 09:18 PM   #158
FyrFyr
FyrFyr's Avatar
Looking good
FyrFyr is offline   Reply With Quote
Old June 22nd, 2017, 12:54 AM   #159
cross measured to ensure the front spacing was correct for front mounts, then referenced the axle in regards to the trans crossmember bolts to verify axle was centered. Front mounts are welded in, got some running around to do tomorrow, hope to be welding in the rear spring hardware on Friday or saturday morning.
I'd like to tow the boat to the lake sunday morning for some fishing before my wife goes to the RHCP concert. We'll see how that goes. Definitely going to need to lift the rear a few inches... and it looks like i have clearance for at least 35's now...
Old June 22nd, 2017, 06:12 AM   #160
k5jess
k5jess's Avatar
Think you can get by with a zero rate? Or are you going to have to go like 2-3" springs?
Page generated in 0.46284 seconds with 86 queries
