I am looking at putting a moser 1 piece in my wide track cj-7, my question is how does the axle shaft keep from sliding out of the bearing? On my stock two piece the shaft is tapered towards the outside so I can see how the retainer holds the bearing in place and the taper keeps the shaft from coming out, with a 1 piece axle I am guessing the bearing has to slide on from the inside but the retainer would only hold the bearing not the shaft in place. Does this come with a circlip to keep the shaft from sliding out?
Also, will I need a press to put the wheel bearing on the axle shaft?
thanks in advance
thanks in advance
