Adj. Cam Bolts, TJ Coils, tie rod, tire carrier, more
12K views 198 replies 14 participants last post by  snodevil
#1 · (Edited)
---- Rear upper control arm adjustable cam bolts for 97- 06 TJ. I believe these are made by pro comp. I bought them and ended up not needing them with my adjustable arms. These are to get adjustment in your pinion angle. $35.
http://www.jeeperz-creeperz.com/degree-bolt-rear-p-5200.html
---- stock TJ spare tire carrier bracket $10
http://i178.photobucket.com/albums/w243/snodevil11/stuffforsale105.jpg
---- Stock TJ coil springs $20
http://i178.photobucket.com/albums/w243/snodevil11/100_3869.jpg
---- Stock TJ steering $20 (Always good to have a trail spare!)
http://i178.photobucket.com/albums/w243/snodevil11/100_3833.jpg
http://i178.photobucket.com/albums/w243/snodevil11/100_3825.jpg
---- Stock Tj front brake lines ( caliper to frame ). $5 pair
---- Please PM me with interests. ----
See less See more
#2 ·
sway bar disconnects
Will these work on a pro comp lift? If you do have all the hardware I am interested.
---- Rough Country front or rear double sway bar disconnects for 4" - 6" of lift. Can use for either end and they are adjustable in length between the two lift sizes. I have the adaper u brackets that are used to mount them to the front swaybar. I belive I have most to all the hardware. Brand new, never
used. $40
#6 ·
I have all the hardware for the front setup except one nut & bolt that goes through one of the u brackets and attaches to the swaybar. Must have lost it somewhere. Look at my pics and you'll see which one I'm talking about. It is a 1.25" length. Not sure what diam. yet. I'll gauge the other one to find out for you. I imagine you could pick one up at your local hardware store cheap.
You have insufficient privileges to reply here.
