"The Predator" another YJ build.
70K views 606 replies 40 participants last post by  CheapThrillB2
#1 ·
This is my first time starting a build thread. Started out as 1990 jeep Wrangler 6cyl auto. Not running. Previous to it i had a 1986 chevy 3/4 ton pickup. The had a head on collision.
Motor, trans, tcase, axles, and YES the chevy emblem were put into the jeep.
Id start at the beginning, but dont know how to upload actual pictures. So ill start with a few years ago. With lots of pictures, every one likes pictures.
Sent from my SPH-D710 using Tapatalk 2
See less See more
3
#2 ·
Frame removed for the rear straightening and raising for backwards xj springs.
Pic2
Side view of frame cut and removed, with xj main leaf in there.
Pic3
Body notched and tubes ran through for bumper attachment.
Pic4
Side view of the frame straightened and put through rear of the body. Welded on, but not fish plated yet.
Pic5
Pretty much finished with stretch and xj spring install. Bimper reattached. Puts my wheel base at 100".
Pic6
View of custom stanless fuel cell, moved up through the floor under the rear seat.
Pic7
Rear view of 30 gallon fuel cell..holds LOTS of premium fuel.
Pic8
Bottom view of 3/16" skid plate protecting 30 gallon 14 guage stainless fuel cell.
#3 ·
Pic1
After moving axle back i had to re make traction bar, and its bracket. I used this time to separate my bars more from 6" to 9" to help control ths 39.5s a little better.
Pic2
Old traction bar top, new traction bar bottom..lots stronger 1.5" 1/4" wall dom.
Pic3
Belly shot, needs a skid plate. On the up side after moving my axle back i could move my cross member up 4" from where it was, this should help lots in the trails. No more droopy gut/muffin top.
Pic4
Pic of newly installed, 98 dodge ram 2500 master cylinder. Waaaay better brakes. One of the easiest mods to the jeep with tje best results...so far.
Pic5
At the same time i stretched the rear, may as well shave my 14 bolt, so this is a pre pic..
Pic6
This is an after the 14 bolt shave..
Pic7
This is how much was removed.
Pic8
This is a rear lower shot of the almost finished stretch and shaved jeep...
#4 ·
Pic1
Here is a pic of the stretch, stance after all the work was complete.
Pic2
Next batch of picz are me testing out the flex after the stretch.
#6 ·
Now after moving the motor trans, t case up 4", i decided to finally get serious and do a 1/4" skid plate. So here is a pic of the fabrication of it.
The last is a pic of the installed skid plate..love it.
#7 ·
Pic 1
On top of the louvers in the hood,i decided to vent the engine compartment and help kool it a little better.
Pic 2
Disassembled the iroks so i can get to welding all my bead locks on.
Pic 3
Just a quick fitment check.of the DIY beadlocks..
Pic4
Inner rings tacked on
Pic 5
First one welded and cleaned up. Double pass with the mig. Hope they hold air.
Pic 6
Before and after the anti coning rings were on
Pic 7
Outer rings primed ready for paint.
Pic 8
Painted outer rings...look nice
#8 ·
Pic 1
Inner rings painted..
Pic 2
First set bolted..wow thats alot of bolts, all torqued and filling with air. Lets hope no leaks. Turns out they hold air for Very well.
Pic 3
Finished product, all full of air and mounted to jeep. Sweet..now for some carnage. We will c what happens to the 10 bolt front with all that traction.
#9 ·
Did some wheeling at the blessing of the jeeps this weekend, as usual something always blows up. Well here is the pictures of the carnage.
Pic 1
Twisted spring shackle, should have been 3/8" or gusseted.
Pic 2
Blew a usa alloy u joint, and took ears out on the 10 bolt.
Pic 3
Bent chromoly cross shaft
Pic 4
Twisted splines on the chromoly outers for the 10 bolt.
Good weekend..lol i see a dana 60 working its way up front soon.
#10 ·
Pic 1
Got myself a superduty dana 60 front with factory 4.30 gears. Good deal, now for the real work. Going to make this superduty 60 a passenger side drop.
Pic 2
Getting a jig built to hold the axle where i need it..
Pic 3
Tubes all swapped and new 4.88 gearz and spartan locker installed.
Pic 4
Close up of gearz and locker installed...nice
Pic 5
Pic of the 10 bolt removed, niw to remove all my leaf spring hangers..
Pic 6
Hangers removed getting ready for triangulated 4 link.
Pic 7
More with no brackets and no axle.. Getting closer.
Pic 8
60 setting in place, selling whatever i dont need any more for air shocks..
#14 ·
Well made myself a mini press brake for my shoo press so i can get to bending some heavy steel for trusses, frame brackets etc..
Also got some 1/8" wall 1.5" dom for shock hoops. Some pvc for practice fit links, and tore down two turbo 350 trans for some part $...and a third on its way tomorrow..wahoo.
Also stole a really good idea from a friend. A double shear pitman arm..i like it.
Try to get some actual work done on it tomorrow. :thumbup:
#22 ·
Well, i guess with all the pictures i should atleast give everyone a description of what its built of..
1989 jeep wrangler
Engine!
Merlin 350 nodular iron block bored 60 over into a 360.
KB hyper pistons
Hbeams
Steel crank
Wold products mowtown 220 heads w/2.05 intake forgot exhaust and cc sizes.
Headers
Comp cams 286H w/hydraulic lifters. (should have done solids)
Comp cams full roller rockers, w/ 3/8" push rods
Edelbrock performer intake..(helps keep power band lower)
Demon 800 carb..
High flow aluminum water pump
Psc power steering pump
200A alternator for the winch and dual optimas (which suck btw) can never hold a charge.
Custom shertmetal snorkel/air intake.
Drive train
Custom built turbo 350 trans with manual valve body and 3200 stahl 10" converter
Twin stick np205 with 32 spline front output. 1410 rear yoke, flanged front
1/4" wall drive shafts
Shaved, welded, disc braked, cross drolled rotors, 14 bolt rear with 1410 yoke, and 4.88 gears, sitting under backwards xj springs
Front is a 03 superduty front with Spartan locker and 4.88 gears, soon to be 4 linked
Where i want to be..
Full hydro front, four linked rear, fuel injection. Sounds good for now.
#25 ·
Cant get it to copy to here..
Anti squat: 110%
Roll center height:5"
Roll axis angle:29°
Travel axis angle:179°
Travel roll center:17.9"
Travel roll axis:22.42°
Pinion change:124.34°
Dont know if these are good or bad, everything seems good to me BUT the pinion angle change
Ill try to upload the whole excel sheet with all my numbers, hopefully someone will be able to tell me what to change for improvement.
