Selling my drivers side drop 609 front axle project. It started out as a new stamped steel ford 9" housing that I cut down and sleeved the tubes with 3.5"x.25 dom tube. The shafts, C's and knuckles are factory super duty Dana 60 parts. So it's the same width as a 99-03 f250.
The third member is a refurbished unit from Quick Performance with a 35 spline spool and 5.43 gears.
Housing comes with:
Third member complete with gears and spool.
Inner and outer axle shafts with brand new spicer u joints.
Brand new ball joints.
Brand new wheel bearing assemblies (8x170 bolt pattern).
Factory knuckles.
2 pieces of 1.5"x.25" dom tubing for steering.
You will need to purchase:
Locking hubs or flanges.
Axle seals. - https://m.summitracing.com/parts/aaf-all72100
TRE or heims for steering.
Mounts for your application.
Brakes.
I was planning to put a full truss on the housing, and I recommend you do the same. Housing has minor surface rust from sitting in the garage.
Asking $1500 for everything. Looking for cash but may entertain trades. Located in Fenton 48430. Sold as-is.
Housing comes with:
Factory knuckles.
Brakes.
