Considering I use it everyday at work and through most the day. I'm impressed. Holds a good charge. Charger is same as my Samsung. Dropped it a bunch of times, no issues.
I love my Dewalt 20V MAX work light. Uses the same batteries as my drills, driver, and impact so it's easy. Plenty bright and pretty adaptable to different orientations. If you have a certain type of cordless tools, see what lights they make for it. They're cheap.
I just ordered this and will upgrade it with a "fusion 36" LED bulb, supposed to be 1000 lumens. And for when that is too bulky I plan on grabbing the E-Z red CheapThrillB2 mentioned also.
Snap on has a new small light out. Very bright iirc its 220 lumens? Fits in a shirt pocket has a magnetic base and uses a mini usb to charge. Works great in tight spots. I bought 3 for myself and 3 for my Dad for xmas.
Ever used a good headlamp? Try a good one and you will never want to mess with work lights like that again. Light is always shining right where you are looking, don't have to find a good spot to hang it on, doesn't cause shadows because its shining from a different angle than where you are looking etc. My work lamps have sat on the garage shelves for years unused.
I use a 12 volt spot light with a magnetic side for general lighting.
For the important stuff a headlamp works great.
A small bright battery powered pocket light with a magnetic base will let you see all those hard spots in the mean time. Just take a small metal one that Harbor gives away for free an stuff a magnetic strip on the side. Works great for little cash.
Some people may get a chuckle out of the HF stuff but I would have given $20 for one of these last week when I had to patch up a fuel line and my other light died before I even got the first cut made. Holding a mini mag in your mouth for that long really makes you greatful you were born a man. :sonicjay: :sonicjay:
My tool guy had another on his truck, exchanged with no questions.
Related Threads
4.2M posts
30.9K members
Since 2005
