5M views 67K replies 500 participants last post by  jeepfreak81
#1 · (Edited)
My cat might be kinda old, But I would bet he can kick most other cats ass.
Update: September 2014
The cat that started this thread is not longer with us.
R.I.P. "The Michael"
#56,808 ·
I love small engine work.
It's really what I should get into for a job. I'm pretty good at it.
Too bad my back is still fucked.
Hopefully physical therapy will help.
My lawnmower is leaking oil from the engine onto the top of the mower deck.
I may have put too much oil into it at some point. It leaks bad too. Can't finish my lawn without putting in more oil. Runs great otherwise.
How do I fix it?
:d:
#56,809 ·
How do I fix it?
:d:
Could be a few different things. If it is a vertical shaft mower, First seal I would check would be the lower crank main seal.
Depending on the engine you can replace them with the engine together, but you do have to pull the engine.
#56,818 ·
Seriously considering buying a boat. I grew up on the water and miss it, a jetski doesn't give me the same feeling anymore.
We have a sea raider jet boat we are getting ready to sell.
Sent from my SM-N910V using Tapatalk
