Originally Posted by PetalMel
sometimes the most economical way to do something "upfront" isn't the best plan down the road. Not sure what Chris talked about in detail, but I know that he often will quote "the cheap way out" and then will provide some rationale to spend a bit more upfront to do better ductwork, etc. so that longterm efficiency/quality and the like is better.
From what he shared with me sounded like Mom is getting pressured from her kids to get A/C :tonka: My dad was the same way--used "window shakers" for years until he finally broke down and got Central Air. Then he couldn't believe he had waited so long to get it installed.
Best of luck convincing mom.
yes, we have been pressuring them to get AC for over a decade...
I have been employed, in one fashion or another with the real estate market. the size of the house/land, and location are now rapidly pushing that house into the high 200's, low 300's price range.
however, the lack of AC, and some deferred maintenance are putting market pressure in the opposite direction, as well as this state's employment issues.
apparently, another brother is looking into something that I guess is common out where he's at. attic installed, gravity fed mini units. (the way he described it, is similar, but slightly larger than "window shakers".
I guess the thought process being to install one in the bed room wing, and one in the living room wing, the latter of which would trickle down through the open/entry/landing area and into the already naturally cooler lower level
I fully and totally understand my mom's reluctance to part with the house on so many levels, but eventually she will be forced to accept that it's too much to maintain for one person. (nearly 2 acres, partially wooded, 5 bedrooms, 3 baths...)
again thanks for the estimate, and I apologize for any lack of follow through. with so much on her plate, it's not always easy for her to make a decision, or pull the trigger on something like this.
