Go Back   Great Lakes 4x4 > 4x4 Talk > Quads and Bikes
Old July 1st, 2008, 11:43 AM   #1
mikeswmikesweat73
Crazy
mikeswmikesweat73's Avatar
1987 Kawasaki KLR 650 Electrical problem
So I am driving to work yesterday and lose all power at about 55mph. No power at all for about 5 minutes. Then it miraculously starts back up and I am on my merry way. Get on the Eway does it again. wait about 10 minutes starts back up with a lot of cranking. Turn around get off the Eway stops for good this time no power even after I got out of work. Go out this morning undo the battery hook it back up. Starts ok, ride it for about 10 hard minutes. Does the same thing twice. I am thinking it's the voltage regulator, but I am no mechanic. PLEASE HELP. can I test the voltage regulator? could it be the ignition switch? what else might be overheating? Any help would be greatly appreciated.
Thanks,
Mike
mikeswmikesweat73 is offline   Reply With Quote
Old July 1st, 2008, 11:51 AM   #2
fsumotorhead
뒤죽박죽이다
fsumotorhead's Avatar
my shot in the dark would be a piece of dirt in the carb
fsumotorhead is offline   Reply With Quote
Old July 1st, 2008, 02:37 PM   #3
Mike Hancho
this is my boomstick?
Mike Hancho's Avatar
no engine power or no electrical power? I also have a klr650
Mike Hancho is offline   Reply With Quote
Old July 1st, 2008, 10:34 PM   #4
mikeswmikesweat73
Crazy
Yeah no engine or electrical power should have clarified that, sorry.
Old July 1st, 2008, 11:06 PM   #5
booblinker
Wrecking a Focus is Cool
booblinker's Avatar
Send a message via AIM to booblinker
Coil, Or bad ground.
NarrowTrail4X4
-2007 Ninja 500(DD)
-93 Ford Ranger 4x4 3.0 5 speed on stockers DD
-1984 ATC200x
-1970 XR185
booblinker is offline   Reply With Quote
Old July 2nd, 2008, 05:48 PM   #6
Mike Hancho
x2...at least its a place to start
Old July 2nd, 2008, 06:58 PM   #7
unclebeaner
Ice Ice Baby
unclebeaner's Avatar
x3
coil or bad connection
Mr. Badluck
[MUDFLAPS]: ALL GIRLS LIKE IT IN THE ASS
unclebeaner is offline   Reply With Quote
Old July 3rd, 2008, 03:20 AM   #8
mikeswmikesweat73
Crazy
Thanks, I've been checking the grounds. I am taking it in in the morning to have the coil, cdi, stator, voltage regulator checked I appreciate the input and I'll let you know the outcome
Old July 5th, 2008, 03:05 AM   #9
mikeswmikesweat73
Crazy
Turns out it was a god damn corroded fuse box. I've got it running like a champ now, thanks,
Mike
Old July 5th, 2008, 07:53 AM   #10
good to see your up and running again. just an FYI for you. Kaws are notorious for not using weather proof connections. I would suggest to you to use dielectric grease in all the connections where any water can reach them. it will help in the long run to stave off corrosion.
Old July 5th, 2008, 08:42 AM   #11
Nuggets
BDMC
Nuggets's Avatar
I was gonna guess bad ignition module but you beat me to the fix. Glad you got it.
Nuggets is offline   Reply With Quote
Page generated in 0.18407 seconds with 35 queries
