Old April 7th, 2006, 08:20 AM   #1
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Suburban inside door panel removal?
I need to replace the driver side mirror on my 99' Suburban. How do you remove the small panel(triangle shaped) behind the mirror? Is it just clipped on? I've pulled on it pretty hard, but it doesn't seem to want to pop off. I don't want to try any harder and break the clips....any easy tips?
Roadhouse is online now   Reply With Quote
Old April 7th, 2006, 09:31 AM   #2
jeepfreak81
80 inches of fun
jeepfreak81's Avatar
If its anything like my s-10 I had it comes off with the rest of the door panel... easiest is to get one of the removal tools from the store, they are only a couple bux, it lets you 'try' to reuse the clips that hold the whole damn thing on. My dad just replaced his mirrors as the motors went out, I can call him later and ask.
The Freak YJ
Old April 7th, 2006, 09:36 AM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Its a small seperate panel on my suburban...Its triangle shaped about 6" on all sides. At least is seems to be seperate from the rest of the door panel.
Old April 9th, 2006, 07:47 AM   #4
AWK
AWK's Avatar
It's held on by Christmas trees (small barbed retainer)
Remove the trim panel from the door by completing the following steps:
Using the J 38778 , carefully pry the retainer from the door.
Pull upward in order to release the extension from the trim panel.
Remover the retainer from the extension
Mirror Replacement
Removal Procedure
Remove the trim panel upper extension. Refer to Trim Panel Replacement - Upper Extension .
Remove the access hole plugs.
Remove the nuts securing the outside rearview mirror to the door.
Remove the outside rearview mirror from the door.
Disconnect the electrical connector.
AWK is offline   Reply With Quote
Old April 9th, 2006, 07:47 AM   #5
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
nevermind figured it out, and replaced the mirror.
Page generated in 0.10145 seconds with 23 queries
