Go Back   Great Lakes 4x4 > 4x4 Talk > General Tech > General Tech FAQ
Old March 29th, 2008, 05:05 PM   #1
big burt
big burt's Avatar
Send a message via AIM to big burt
holley power valve ???
i have a holley truck avenger 670 carb and im havin trouble understanding what the power valve does. there in a power valve block off in the carb right now, but i havnt installed it on the engine. will this cause a problem and if so which power valve should i try? thanks alot
big burt is offline   Reply With Quote
Old March 29th, 2008, 05:21 PM   #2
Kodiak450r
Kodiak450r's Avatar
Send a message via AIM to Kodiak450r
taken from chevy high performance. http://www.chevyhiperformance.com/te...ems/index.html
What It Does
Most carburetors employ what is generally called a power valve circuit. This circuit enriches the air-fuel mixture when the carburetor goes to wide-open throttle (WOT). At WOT, intake manifold vacuum drops to almost zero. When this occurs, the power valve opens and directs more fuel into the main power circuit, in addition to fuel delivered by the main jets. The Holley power valve employs a small rubber diaphragm that is opened by a small coil spring. The valve is held closed whenever sufficient engine vacuum is present. At WOT, engine vacuum disappears and the power valvespring opens the valve, directing fuel through a small, precise orifice in the metering block called the power valve channel restrictor. This restrictor determines the amount of additional fuel delivered to the engine.
Power valves are used most frequently on the primary side of a Holley carburetor. They allow the carburetor to operate with much leaner main circuit jetting for part-throttle fuel economy. Then, when the throttle is slammed open, the power valve adds additional fuel, creating the rich air-fuel ratio needed for WOT operation. Most Holley power valve circuits are designed to add the equivalent of 8 to 10 jet sizes of additional fuel. Holley does offer a power valve block-off part that closes the power valve circuit, but this means the jet size must be increased in order to compensate for the lost power valve circuit fuel. Imagine how bad your fuel mileage would be if you had to add 10 jet sizes to the primary side of your carburetor!
Kodiak450r is offline   Reply With Quote
Old March 29th, 2008, 05:56 PM   #3
big burt
big burt's Avatar
thanks alot now all i need to know is a base line on a power valve.
Old March 29th, 2008, 06:52 PM   #4
Kodiak450r
Kodiak450r's Avatar
i'd start off with something in the range of 6" of Hg to see how it reacts first. since it had a blocked power valve you have to look at the jetting and see if it has fatter main jets since it didn't have a power valve. you want the power valve so that when you crack the throttle to wot there isn't a bog from lack of fuel. a wideband O2 sensor would be most helpful for tuning. that way you can see what the engines A/f ratio is during part throttle and wot operation.
Old March 29th, 2008, 06:54 PM   #5
Kodiak450r
Kodiak450r's Avatar
forgot to mention. you'll want the power valve to come in sooner if you have a heavy bog so a higher number valve would need to be put in. if it goes way to rich then you'll want a lower number so it comes in later. hope this helps
Old March 30th, 2008, 07:31 PM   #6
big burt
big burt's Avatar
ya that helps alot. the jetting is at stock now and i have a 6.5 hg valve to put in it. thanks alot for the help
Page generated in 0.14763 seconds with 25 queries
