Old March 29th, 2008, 03:21 PM   #1
JUSS10
4given4x4.com
JUSS10's Avatar
dana 300 twin stick
so i came across this website:
http://www.jeepgod.net/twind300.html
It is a home built dana 300 twin stick. guy said it only costs around $30 if you do all the machining yourself. So i thought i would give it a try. It became todays project for me. the site gives a list of all parts and dimensions. ran to TSC down the road and got most the parts there. walked out with a bill of less $30. I started by cutting all the flat stock to length and drilling all the holes. This is probably the most time consuming part of the project. here is a pic of all the finished parts
as you can see in the picture, the piece to the lower right is twisted 90 degrees in the middle. I used MAPP gas for this. IT worked but it takes a long to get a piece of 1/4" flat stock to twist 90 degrees. I'm sure a torch would have made easy work of it.
Once those were twisted i took them to the table grinder to level out the ends a little better. I then bolted them to the t-case.
Next i installed the adjustable connecting bracket thingys. they have multiple holes so it can be setup just the way you like it. they bolt up using 1/4-20 hardware.
I then installed the upper mount pieces and the arms that pivot on them. as you can see i had to bend the outer arm to reach. this is the way it was shown on the site were i got the idea. i couldn't get it to work the way i wanted so i ended up modifying it. here is a picture of how it first looked.
and here is a picture of how i made it work
i made a new piece as i destroyed the one i bent. this time i took two 1/2" nuts and drilled them out. welded them together then welded them to the new piece. this worked as a perfect spacer that lined everything up perfectly. here is a top view of that
I have yet to weld on the shifter handles but will do that soon. all in all it seems to work real well. i had to modify the original design to something that i feel works better. will post more pics of it finished once i get to that point.
JUSS10 is offline   Reply With Quote
Old March 29th, 2008, 07:38 PM   #2
I love you.
Feel free to steal my lever idea if you don't have one yet.
It's 1/2" hex rod that I twisted with a torch :)
Old March 29th, 2008, 10:14 PM   #3
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
I'll post a pic tomorrow. I went with the old standby of 1" wrenches. :tonka:
TJontherox is offline   Reply With Quote
Old April 2nd, 2008, 07:19 AM   #4
tweak
Are we there yet?
tweak's Avatar
Updates?
tweak is offline   Reply With Quote
Old April 2nd, 2008, 08:59 AM   #5
JUSS10
4given4x4.com
JUSS10's Avatar
don't have time to work on it during the week because of work and school. this weekend i should have an update. if anyone is interested i can post the drawings.
Old April 2nd, 2008, 09:02 AM   #6
tweak
Are we there yet?
tweak's Avatar
Yeah, I would be intrested in the drawings and would love to see the pics of your finished product (and hear how well you like it).
Old April 2nd, 2008, 08:22 PM   #7
preatty much the same as my design works good..
I put a 45 deg bend in my levers and used old bump stops for knobs.. much better feel than trying to grab onto a little dinky plastic ball
Old April 3rd, 2008, 10:31 PM   #8
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
I think you need longer levers! lol
looks good, let's see some finished pics
71jeepster is offline   Reply With Quote
Page generated in 0.15524 seconds with 29 queries
