February 10th, 2008, 06:31 PM
#1
Steel Guru
New Heim/Johnny Joint 1pc link bracket
Thought we would put out an affordable alternative for mounting your links to your frames. These are built from 1/4" A36 and are formed 3 different ways to make this unit the most rigid available. Not to mention one of a kind in design! We cut out a plug weld slot down the center to increase the welding surface by 35%! The inside dimension of these are 2 5/8" between the mount holes so that you can use these w/ any heim or johnny style joint. The mount holes are 9/16" diameter and can easily be reamed for larger heims. You guys demand the best so here is the best part we sell these for $8.95ea plus shipping and trust us alot of these can be crammed in a USPS flat rate box! Compare similiar parts @ $20 ea Realize we are not trying to retire from every sale!
www.greatlakeoffroad.com
Shawn4x4@greatlakeoffroad.com
For Quick Order Processing Call Tonya 260-387-1428
