Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Suzuki Tech
Old January 3rd, 2008, 05:52 PM   #1
A4X4SPIT
A4X4SPIT's Avatar
bad running sami
I m working on a samurai that idles but when you step on the gas it acts like its not getting gas we have changed carbs still the same changed fuel pumps still the same by passed stock fuel filter & put new clear one close to carb & its full of gas also tried swaping control box still the same the timing seems to be right & the air filter isnt plugged Im stumped any ideas????
A4X4SPIT is offline   Reply With Quote
Old January 3rd, 2008, 08:28 PM   #2
Kodiak450r
Kodiak450r's Avatar
Send a message via AIM to Kodiak450r
if you open the throttle and spray some carb cleaner in it does it pick right up? need to find out if it's fuel related or ignition.
Kodiak450r is online now   Reply With Quote
Old January 4th, 2008, 12:33 AM   #3
scottie
867-5309
scottie's Avatar
Did you try Disconnecting the electrical to that high idle thingy, I think its called the TMSV or something. Has 2 vacuum lines going to it on the front of the engine on the Right Hand side.
Old January 4th, 2008, 07:23 AM   #4
A4X4SPIT
A4X4SPIT's Avatar
ill try both those ideas after work
Old January 4th, 2008, 07:49 PM   #5
A4X4SPIT
A4X4SPIT's Avatar
IVE GOT IT IDLING & YOU CAN REV IT UP but It dies when I try to move it Ive checked all vacuum lines & they look like the stocker I have .the timing seems good Im going to try to swap distributor
Old February 22nd, 2008, 09:26 PM   #6
chevycummins
chevycummins's Avatar
Plugged exhaust? Cat converter might be all broken up and plugging the exhaust pipe. It might idle fine but bog down when reved up. Might try to loosen the exhaust pipe infront of the converter and see how it runs then.
chevycummins is offline   Reply With Quote
Page generated in 0.13275 seconds with 25 queries
