Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace. Over 4000 readers daily! > 4x4 Vendor Area
4x4 Vendor Area Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Old January 1st, 2008, 10:32 PM   #1
greatlakeoffroad
Steel Guru
Arrow Inexpensive Link Tabs Save $$$ Adding Items Daily
Here is an example of some stuff we had in our library and thought we would start stocking. These are 1/4" thick w/ a 9/16" hole built for a standard johnny joint or can be reamed out for a larger heim. These are a set of 4 matched @ 12 degree setup so that you can use them for lower links off of a D-60 or similiar axle. Realize that 12 degrees is not set in stone and can be manipulated one way or the other very easily. These run $9.95 for the set (4)and can be shipped via a flat rate envelope. Or added w/ any other part for free shipping. Stay tuned this is just a small glimpse of what is coming down the line. Thanks Shawn
www.greatlakeoffroad.com
Shawn4x4@greatlakeoffroad.com
For Quick Order Processing Call Tonya 260-387-1428
greatlakeoffroad is offline   Reply With Quote
Old January 27th, 2008, 02:51 PM   #2
greatlakeoffroad
Steel Guru
1/4" tab w/ 9/16" diamter hole built to be hung from 1 3/4" tube and easily modified to use on 1.5" or 2" tube Also 9.95 for every set of 4
Old January 27th, 2008, 02:53 PM   #3
greatlakeoffroad
Steel Guru
Flat mounting tab for use as a frame mount also from 1/4" mtl w/ a 9/16" hole. Designed for 0 degree mounting but can easily be swung 5 degrees either way. Set of 4 also 9.95
Old April 26th, 2008, 12:33 PM   #4
greatlakeoffroad
Steel Guru
Lots in stock and at very competitive pricing
Page generated in 0.10297 seconds with 22 queries
