December 28th, 2007, 01:58 PM
#3
Swamp Stomper
well, figured it out, the switch was mounted by copper tabs going out to the cable contacts on the end of the motor, loosen then, the the switch slid right off, the cables were long enought to mount this switch to the fender and cut the cables and rout them from the copper tabs back to the motor so everthing still works. It's easy enough, I would do some pics and a quick write up, but since this winch is discontinued, I bet most people already have them set up how they want. I did hear these switches tend to burn out, so if it does, then I'll do the solenoid pack set up...
SWAMP STOMPER
