Go Back   Great Lakes 4x4 > 4x4 Talk > Quads and Bikes
Old December 17th, 2007, 01:27 PM   #1
Plowing snow with a 4x4 quad....
Who's got a plow for their quad? How well does it work for snow plowing duties?
Hehehehehehe, looking for reasons to justify getting on.
If you WERE going to use it to plow snow, what would the minimum you'd think would do the job?
Old December 17th, 2007, 01:32 PM   #2
jeeptjpaul
jeeptjpaul's Avatar
There are a couple landscape companies around here that use a quad to plow driveways and sidewalks. Seems like it works well.
jeeptjpaul is offline   Reply With Quote
Old December 17th, 2007, 01:39 PM   #3
mudrunner456
mudrunner456's Avatar
my friend has a yamaha big bear 400 and it does a really nice job
mudrunner456 is offline   Reply With Quote
Old December 17th, 2007, 01:40 PM   #4
daddyman
daddyman's Avatar
I have a Arctic Cat 650 V2 with a 5ft. plow. It worked great this weekend. Last year we had a wet snow, and that made it a little harder. But it still did a good job. I have a winch on it to raise and lower the plow, I can't see using a manual lift on it. Although some people do. And yes, I bought the ATV for plowing snow. The side benefit is the fun you can have the rest of the year.
daddyman is offline   Reply With Quote
Old December 17th, 2007, 01:42 PM   #5
Kodiak450r
Kodiak450r's Avatar
Send a message via AIM to Kodiak450r
i use a plow to do my driveway. i have a 48" plow on my kodiak450 4x4. does a good job, i've plowed up to 18" of snow without traction problems. hardest part is since my plow has manual angling you gotta stop and get off to change angles. i'm going to be getting the new warn angling actuator soon. the other thing i want is a blade scrapper for the bottom made of something other then metal cuz it kinda chews up the pavement when striking objects. they have polycarbonate ones that last a long time and don't harm the ground. but since my dad just bought a snowblower now i'm just gonna build brackets to attach my snowthrower to my quad....
Kodiak450r is offline   Reply With Quote
Old December 17th, 2007, 02:52 PM   #6
busyfixin
busyfixin's Avatar
i think minimum would be an 800, or a 450 polaris diesel. just for justification purposes
Old December 17th, 2007, 03:01 PM   #7
Strangler
Strangler's Avatar
I prefer the manual lift. Winch is awsome to have as a winch, but too slow for lifting/dropping the plow.
Strangler is offline   Reply With Quote
Old December 18th, 2007, 02:44 PM   #8
swampjeep
Swamp Stomper
swampjeep's Avatar
now what plows?
I seen an Eagle for a good price, are they cheep compared to other brands?
YOGI'S PIG GIG '08
yes, it's still on this year
Old December 18th, 2007, 07:56 PM   #9
bayouguy
I got 2 of these now!
bayouguy's Avatar
I have a Kawi BF650 with 54" plow (Warn) that came with the machine as a promotional item ($69)
I have a winch with mine--manual was OK for just a few passes but I have a bad shoulder and with the snow we just got I was glad to have the winch.
X2 on the added benefits the rest of the year.
bayouguy is offline   Reply With Quote
Old December 19th, 2007, 04:56 AM   #10
daddyman
daddyman's Avatar
Originally Posted by swampjeep View Post
now what plows?
I bought mine with the ATV, It's the Arctic Cat Plow made by Warn. They have have a couple of different versions.
Also while I don't know to much about it, Artic Cat also has a diesel. I think it's a 650 single. Supose to have killer torque.
Old December 19th, 2007, 08:04 AM   #11
SHARPMACHINE
IN A HURRY??
SHARPMACHINE's Avatar
I would go with no less than a 350 4x4 to plow with. Another thing to look at is, how easy does the quad go from forward to reverse and back. Some atv's are a pain to switch to reverse.
Quads can plow well, but you will need to keep up on it. You will not be able to move deep heavy or "hardenned" snow very well.
That said, I am looking for a plow for my 400 kodiac??
SHARPMACHINE is offline   Reply With Quote
Old December 19th, 2007, 12:45 PM   #12
daddyman
daddyman's Avatar
The only problem with the smaller 4x4's is the weight. Mine's at about 750lbs . The only time I ever had a hard time was with about 6" of wet snow and the bottom 2 were slush. It still did a good job, just took longer. Any other time it pushes it easy. Even the 8 to 10 inches we had last weekend. I think the extra pounds are your friend when plowing. Oh, by the way, I don't use chains.
Old December 19th, 2007, 12:48 PM   #13
Mr. Beefy
I was givin this name!
Mr. Beefy's Avatar
Send a message via MSN to Mr. Beefy
The new Arctic Cat plows have a power angle option, just an FYI
Mr. Beefy is offline   Reply With Quote
Old December 19th, 2007, 12:50 PM   #14
daddyman
daddyman's Avatar
Damn I didn't know that. I wonder if it will fit the '05 models? It is a pain in the butt to have to get off to tilt it every time.
Old December 19th, 2007, 01:08 PM   #15
Spudy
Spudy's Avatar
Send a message via AIM to Spudy Send a message via MSN to Spudy Send a message via Yahoo to Spudy
As far as traction goes I know of a few people around here who got some old tractor weights and put on their quad for weight. Worked great!
Spudy is offline   Reply With Quote
Old December 19th, 2007, 02:45 PM   #16
Hehehe, I'm a big boy, so I naturally bring the extra weight
Old December 19th, 2007, 06:52 PM   #17
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
There is no better setup than the Polaris Glacier plow. It goes on and off in under a minute takes up virtually no ground clearance.
I have installed a good 80 or more plows in the last 4 years and I still can't get over how well an ATV can move snow. It takes longer because it's smaller but it works very well for smaller driveways.
Old December 21st, 2007, 10:02 AM   #18
unclebeaner
junk lowriders
unclebeaner's Avatar
i had one on my yammy i loved it but sold it like a jack ass. as long as you ride it like a white person you will be fine
Mr. Badluck
unclebeaner is offline   Reply With Quote
Old January 22nd, 2008, 05:42 PM   #19
mikef
me and a few frieds/do workers help out a snow removal company during the big snows. 1 has an artic cat 500 with a plow. it is a life saver, so much so that me and another co worker are planning on buying quads this summer. his is stock and was easily driving through 2+feet of snow at the gm plant in lake orion. it was pushing alot more snow then i though it would as well. you can make alot of cash whoring yourself out to snow removal companies as well. thats what he does. and hopefully i will to. the only down side is that the which cables are prone to breakage, easy fix but kind of annoying also.
mikef is offline   Reply With Quote
Old January 23rd, 2008, 07:25 AM   #20
Ironman
new parts pimp
Ironman's Avatar
Your on crack
www.ironmanoffroad.com
www.glfwda.org support the sport
Ironman is offline   Reply With Quote
Page generated in 0.38753 seconds with 53 queries
