Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace. Over 4000 readers daily! > 4x4 Vendor Area
4x4 Vendor Area Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Old December 11th, 2007, 01:35 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Ruffstuff Specialties Disc Brake Brackets!
We make 12 different Disc Brake Adapters for a variety of axles, 4 of them are weld on brackets so you can do that different axle. Here are a couple of the different 14 bolt brackets available.
14 Bolt Disc Brake Bracket for Single Rear Wheel Axle
14 Bolt Disc Brake Bracket for Cab & Chassis Axle
Of all the brake brackets we make the 14 Bolt is the most popular but overall we have over 3000 sets in use! These work and are fairly priced......$45 a pair after the discount!
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
New Lower Diff Cover Prices!
Gravel Maker is offline   Reply With Quote
Old January 21st, 2008, 11:33 PM   #2
Gravel Maker
Steel Hauler
Arrow Still the best!
These are $45 with the GL4X4 discount and we have over 100 pair in stock!
Dan Fredrickson
916.600.1945
Old January 25th, 2008, 09:49 PM   #3
Gravel Maker
Steel Hauler
Time to add it all up!
And choose the best!
Dan Fredrickson
916.600.1945
Old May 13th, 2008, 11:03 PM   #4
Gravel Maker
Steel Hauler
Arrow Just added one!
The Toyota IFS ('87-95) rear disc brake bracket, these are for the calipers with the small pattern between the bolts.
I don't thing we will make the bracket for the earliest rotors and calipers, the non vented rotors should be replaced for a stronger one.....
Dan Fredrickson
916.600.1945
Old June 13th, 2008, 12:09 AM   #5
Gravel Maker
Steel Hauler
All the time.......
Not just when I get around to it!
Yes, these also use the '73-87 Chevy 3/4 ton Front rotors & calipers........
Just plug in GL4X4 in the discount/coupon code box to get the discount!
Dan Fredrickson
916.600.1945
Old June 13th, 2008, 05:19 PM   #6
chainbrain2002
chainbrain2002's Avatar
hey do you guys make the brackets for the dana 35? ford 8.8? or any others then 14 bolt?
chainbrain2002 is offline   Reply With Quote
Old June 16th, 2008, 12:01 AM   #7
Gravel Maker
Steel Hauler
We do make others.....
We make 2 D70, 3 Toyota, and 4 weld on brackets. We don't yet make those for brackets that are available from the factory, but we do intend to because they are more expesive from the factory......
Dan Fredrickson
916.600.1945
Page generated in 0.13324 seconds with 27 queries
