Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace. Over 4000 readers daily! > 4x4 Vendor Area
4x4 Vendor Area Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Old December 9th, 2007, 01:57 PM   #1
greatlakeoffroad
Steel Guru
Exclamation Strength of GLO products?
Ask around we have plenty of references, fail rate 0% enough said. :chiefwoohaw:
Comp Tested, Customer Approved
Thanks Shawn
greatlakeoffroad is offline   Reply With Quote
Old December 9th, 2007, 02:02 PM   #2
I've hit the crap out of this cover... the rocks fail first (seriously)
D60 cover, with lower drain hole and upper fill hole
With my ram welded to the cover.
99 stroker
Old December 9th, 2007, 02:06 PM   #3
FYI- you should put this in your sig, but I'll post it here for reference
99 stroker
Old December 9th, 2007, 04:31 PM   #4
greatlakeoffroad
Steel Guru
Yes, I should and will thanks for the pimp. Shawn
Old December 9th, 2007, 04:35 PM   #5
greatlakeoffroad
Steel Guru
Updated that..... now take a look at the close up of that cover and what a weld should look like....... Thanks Shawn
www.greatlakeoffroad.com
Shawn4x4@greatlakeoffroad.com
For Quick Order Processing Call Tonya 260-387-1428
Old December 9th, 2007, 04:40 PM   #6
greatlakeoffroad
Steel Guru
And just so you all know typically tread plate is thicker than standard 1/4" smooth plate. Usually around 5/16" thick, not that you would need it look at our warranty..........
Old December 14th, 2007, 10:05 AM   #7
greatlakeoffroad
Steel Guru
Thanks for the orders guys, we are located here in NE, Indiana and most products can be to your area within a day via UPS. Thanks Shawn
Old December 15th, 2007, 09:30 PM   #8
greatlakeoffroad
Steel Guru
Scandalous
Our Quality that is, compare you will see the difference!
Old December 17th, 2007, 08:11 AM   #9
greatlakeoffroad
Steel Guru
Free engineering lessons perfect! Just so you know we have wheeled our products and know they work. Gotta love the simplicity in that idea!
Old January 4th, 2008, 11:01 AM   #10
greatlakeoffroad
Steel Guru
Utilizing 1/4" plate where others w/ 3/8" fail. Again, its all in the design. Our brackets and tabs that are due out shortly you will see the difference.
Page generated in 0.15318 seconds with 33 queries
