Old November 28th, 2007, 02:12 PM   #1
905darryl
spoa lift kit
I am hoping to get some info on wich kit to go with. I would like to get 31x10.5 under my 1985 samurai.any help would be appreciated
905darryl is offline   Reply With Quote
Old November 28th, 2007, 05:27 PM   #2
RDK_YJ88
ZUK You!
RDK_YJ88's Avatar
Im not sure what kit i have but i have 31x10.5's and missing link shackles and it does awesome offroad.
I dont think theres a bad kit since its all stock spings just spring perches and hardware
RDK_YJ88 is offline   Reply With Quote
Old November 28th, 2007, 06:23 PM   #3
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
spring over
90 tracker w/ 3"lift on 31s
99tj sport 3" lift on 33s with a winch
and JPfab. rockrails
suport the sport- www.GLFWDA.org - member
What Lies Beyond Jeep Club of Michigan - member
Originally Posted by a.j. hall View Post
Karmas a bitc*
ouchman is offline   Reply With Quote
Old November 28th, 2007, 09:49 PM   #4
RDK_YJ88
ZUK You!
RDK_YJ88's Avatar
Originally Posted by ouchman View Post
spring over
either im reading this wrong or hes asking for what spring over kit? idk
Old November 29th, 2007, 11:28 AM   #5
scottie
867-5309
scottie's Avatar
any of them, they are all pretty much the same, if you want it quick, don't get it from Rocky-road, and trail-tough is good but it takes 9 business days once UPS gets it for it to make it to michigan.
Old December 2nd, 2007, 06:23 AM   #6
905darryl
thank you scottie
trail tough looks good and theit prices are the most reasonable so far thanks for the info.
Old December 2nd, 2007, 12:16 PM   #7
jimmyroyse
jimmyroyse's Avatar
another place to check,
rockrat can get or has just about everything too;
http://www.rock4xfabrication.com/
and since you are in Canada eh;
http://www.zookpower.ca/mainpage.html
jimmyroyse is offline   Reply With Quote
Old December 2nd, 2007, 04:01 PM   #8
motrctyman
Just The Spouse's spouse
motrctyman's Avatar
Can you fit 31's under a SPOA (4.5") and 33's under a 6" lift? Any trimming needed?
motrctyman is offline   Reply With Quote
Old December 2nd, 2007, 07:38 PM   #9
swampjeep
Swamp Stomper
swampjeep's Avatar
I believe yes and no
my Samy has a 4" lift I believe, sits about the same as one with a SPOA, 31's fit nice, 33's fit but rub alot in turns and flex, I dont' know it 2" more lift would stop all the hitting in flex.
but go buy it
:tonka:
YOGI'S PIG GIG '08
yes, it's still on this year
Old December 2nd, 2007, 08:14 PM   #10
A4X4SPIT
A4X4SPIT's Avatar
Ive lifted a bunch of samis by spring over I usually use 5" lift spring perches U bolts/plates lower shock mounts longer shocks longer brake lines drive shaft spacers and a z drag link or drop pitman arm or a high steer kit to get 33 to fit I cheet the ft axle foward by moving center pin hole in perch /spring plate back a inch or 1.5 "s back
(33 s & no ft rub) I also turn the rear helper spring over and have added a extra leaf to ft to help keep the flat springs from reversing arching
http://www.sky-manufacturing.com/
A4X4SPIT is offline   Reply With Quote
Page generated in 0.27135 seconds with 33 queries
