November 27th, 2007, 11:56 AM
#2
867-5309
is anything wrong with the carb you have now, or are you expecting a performance gain?
Being in Canada, i assume you don't have the hitachi carb, but the aisin carb, which i know nothing about.
Webbers are okay, they can suck at angles, unlike the stock carbs that usually work pretty well almost on their sides. cost can vary, from about 300 bucks to around 800, depending on if you take your intake off and have it machined, if you want more Info on Webbers on samurai's go to zuwharrie.com and look for "sarge"
If your carb is f'd up and you just want a replacement, there are Hyundai Pony carbs, Toyota Corolla Carbs that will also work. Then there are the sidedraft carb options. My-Side and My-Side II from Zuksoffroad.com, it uses on Harley Davidson carb (~$400 total). Then there is the 4 side draft setup ($600) that uses GSXR carbs.
If you want to gain HP, do an engine swap not a carb swap.
My Stock carb needs replacing, i haven't decided if i am going to put the sidedraft kit on it, or just fuel inject it.
