Old March 13th, 2006, 01:13 PM   #1
Toivo
got drank?
Toivo's Avatar
Question Dana 30 questions
any info on why I am gettin grinding noise when in 4wd. Itll work at low engine rpm, but ne rpm over about 1500 and it pops and grinds. Axle joints and u-joints are OK too. I havent ruled out a stretched t-case chain (NP 231) but I think its highly unlikely, seeing as how Ive put over 1000 miles on it since the problem happend. More concentrated on vacuum axle disconnect. Any ideas?
Old March 13th, 2006, 02:09 PM   #2
ned
large member
ned's Avatar
did you open your diff up and look
maybe worn gears??
or broken teeth
ned is offline   Reply With Quote
Old March 13th, 2006, 02:18 PM   #3
Toivo
got drank?
Toivo's Avatar
idk
not yet...but doesnt the one side of the axle shaft spin all the time. regardless of wheter the 4wd is engaged or not?...i thought so..I could be wrong but I kinda figured that if that was the case..then wouldnt just driving it daily make tons of noise and cause serious other problems?
94 XJ with 17's, 37s
00 PSD Crewcab F250 tow rig
NARROW TRAIL 4X4
Old March 13th, 2006, 03:01 PM   #4
Thats your best bet..
First, pull the cover off the vacuum disconnect and inspect it. If it looks ok there, then maybe drain the t-case into something like a gallon size glass jar. Look at the fluid... any metal?
Gotta figure if there's grinding and popping, there's wear.
You can't tell the general location of the sound? Axle or T-case area are a few feet apart..
If the t-case fluid is clean (probably needed to be flushed/refilled anyway, right ;) ), then pull the diff cover.
Also, check the driveshaft CV centering yoke. That makes some nasty noises when it goes, also quite common on any jeep..
Do those things, and report back!
Old March 13th, 2006, 04:00 PM   #5
Toivo
got drank?
Toivo's Avatar
ok
it sounds like the axle to me..as well as a few of my friends think so too..im gonna check the vacuum disconnect here soon. as for the t case drainin..i changed the fluid prolly 1500 miles ago...i will check everything twice again tho..I do not have any lifts my disposal, all I have is a parking lot..and its damn cold n crappy out
NARROW TRAIL 4X4
Old March 14th, 2006, 04:25 PM   #6
silverxj
silverxj's Avatar
It's not unlikely to stretch the chain on a standard np231. It's actually more common than you think, especially if you're in 4wd often.
Just changing the t/case fluid will have no adverse affect on a stretched chain. It's not like it's a rubber band and going to collapse back to it's original shape ... I wish mine had.
If you find that it ends up being the chain, replace it with a wide chain kit...
4.7L, aw4, 4:1 231, 44, 60, 5.13's, 39.5", H1's.
silverxj is offline   Reply With Quote
Old March 14th, 2006, 10:15 PM   #7
Toivo
got drank?
Toivo's Avatar
no?
eh ok sounds good.....btw doing 4wd drifts for a long time one icy day COULDNT have had anything to do with that
NARROW TRAIL 4X4
Page generated in 0.13051 seconds with 27 queries
