| Jeep tech FAQ Look here first! |
80 inches of fun
8.8 tech
Figured I would post my links to 8.8 tech i have aquired, never made my own because these were more then sufficient. If people search I hope this will come up for them.
at a glance... These are the codes you will need when out shopping for your 8.8 Axle tag codes: 3L73 = 3.73 LS 4 10 = 4.10 open 4L10 = 4.10 LS and so on Door codes: 43 Open 3200 3.08 41 Open 3200 3.27 42 Open 4.10 46 Open 3.73 45 Open 3200 3.55 D4 Limited Slip 3200 3.73 D2 Limited Slip 4.10 L73 Limited Slip 3.73 Here's all the specs, measurements, and misc crap about the 8.8 you'll ever want to know. Ford 8.8 specs: Weight (complete assembly w/ brakes etc.): 174 lb. Axle shaft strength: 6,500 (lb. ft.) Drivers side Ford brake hose #:F5TZ-2282-A Passenger side brake hose #: XL2Z-2282-AA Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm Driveshaft Flange: Spicer Part Number 2-2-1379 Measurements: O.D. of tubes: 3.250". Tube thickness: .250" (some are .188”!) Ring gear diameter: 8.800". Ring gear bolts: 7/16" dia. (qty. 10). Pinion diameter/splines: 1.625 / 30. Axle shaft/splines: 1.320 / 31. Rotor thickness (where it mounts to axle is .250"). Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35). Hole diameter for ABS sensor in top of housing: .811". Centerline of housing to C/L of pinion difference is 3.875" toward the P/S. Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35). all taken from http://members.cox.net/quanno/ford88.html there are comparison pics to the D35 there as well also www.stu-offroad.com has TONS of info... not just on 8.8 axles
The 1946 CJ2A "Project USS Hermitage AP54" The Freak YJ 1966 M416 1/4 ton Military Trailer |
#3 |
I love you.
Remember ALL explorer 8.8's are 31 spline. Drum OR disc.
#4 |
8.8 - d44 - d35 axle comparison.
#5 | |
80 inches of fun
Should mention RANGER 8.8's were Drum, 27 spline (IIRC) and i believe narrower... though on this I am not certain... anyone care to confirm?
| Thread Tools | |
| Display Modes | |
