My 91 had a leak and it was on the bottom of the tank. The problem is if you get a small rock in between the rear factory skid and the tank it will wear a hole through the tank and start leaking. I replaced mine last summer. I bought a new tank from LMC. They have a catalog that has almost every part for all years of blazers and jimmys. Just make sure its close to empty before changing it. Mine was 31 gallons.
Only hard part was getting to the bolts near the rear bumper. looooong extension on a socket. Also wresting it in between the hitch. Also while getting a new tank may be a good idea to get new straps that hold it. You will probably twist off the old ones tring to get the nuts off.
After I got the tank in I left the skid plate off. I do not wheel it I drive it on the road everyday. 235000 miles and still going
