please note:98+ uses OBD II and a scan tool is required to access codes.
the codes are different for OBD II as well
ACTRON is one generic scanner that can be used. the plug is located under the dash, on the left hand side of the steering column on U.S. models (left hand drive)
write ups, including using a labtop to access codes, etc!
http://www.stu-offroad.com/engine/obdii/obdii.htm
both obd 1 and OBD II codes
http://jeephorizons.com/phpbb/viewtopic.php?t=2719
list of obd II codes
OBD-II codes
1996 models and later
P0010 A Camshaft Position Actuator Circuit (Bank 1)
P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank 1)
P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing Over-Retarded (Bank 1)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0121 Throttle/Pedal Position Sensor/Switch 1AT Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch 1AT Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch 1AT Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0129 Catalyst Monitor Slow 02 Sensor (Bank no. 1 Sensor no. 2)
P0131 Left Bank and Upstream 02 Sensor Voltage Shorted to Ground
P0132 Left Upstream 02 Sensor Shorted to Voltage
P0133 Upstream 02 Sensor Circuit Slow Response (Bank no. 1 Sensor no.1)
P0135 02 Sensor Heater Circuit Malfunction (Bank no. 1 Sensor no. 1)
P0137 Left Bank Downstream or Downstream and Pre-Catalyst 02 Sensor Voltage Shorted to Ground
P0138 Left Bank Downstream or Downstream and Pre-Catalyst 02 Sensor Shorted to Voltage
P0141 Downstream, Left Bank Downstream or Pre-Catalyst 02 Sensor Heater Failure
P0152 Left Upstream 02 Sensor Slow Response
P0162 Charging System Voltage Too Low
P0171 Right Rear (or just) Fuel System Too Lean
P0172 Left Bank or Fuel System Too Rich
P0201 Injector no. 1 Control Circuit
P0202 Injector no. 2 Control Circuit
P0203 Injector no. 3 Control Circuit
P0204 Injector no. 4 Control Circuit
P0205 Injector no. 5 Control Circuit
P0206 Injector no. 6 Control Circuit
P0207 Injector no. 7 Control Circuit
P0208 Injector no. 8 Control Circuit
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder no. 1—Misfire Detected
P0302 Cylinder no. 2—Misfire Detected
P0303 Cylinder no. 3—Misfire Detected
P0304 Cylinder no. 4—Misfire Detected
P0305 Cylinder no. 5—Misfire Detected
P0306 Cylinder no. 6—Misfire Detected
P0307 Cylinder no. 7—Misfire Detected
P0308 Cylinder no. 8—Misfire Detected
P0320 No Crank Reference Signal at PCM
P0340 No Cam Signal at PCM
P0351 Ignition Coil no. 1 Primary Circuit
P0420 Left Bank Catalytic Converter or just Catalytic Converter Efficiency iiure
P0441 Evaporative Purge Flow Monitor Failure
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evap Purge Solenoid Circuit
P0455 Evaporative Emission Control System Leak Detected (Gross Leak)
P0456 Evap Leak Monitor Medium Leak Detected
P0460 Fuel Level Unit No Change Over Miles
P0462 Fuel Level Sending Unit Voltage Too Low
P0463 Fuel Level Sending Unit Voltage Too High
P0500 No Vehicle Speed Sensor Signal
P0505 Idle Air Control Motor Circuits
P0600 PCM/Serial Communication Link Malfunction
P0601 Internal Controller Failure
P0622 Generator Field Not Switching Properly
P0645 A/C Clutch Relay Circuit
P0700 Transmission Control System (MIL Request)
P0711 Transmission Fluid Temperature Sensor, No Temperature Rise fter Start
P0712 Transmission Fluid Temperature Sensor Voltage Too Low
P0713 Transmission Fluid Temperature Sensor Voltage Too High
P0720 Low Output Speed Sensor RPM Above 15 MPH
P0740 Torque Converter Clutch, No RPM Drop At Lockup
P0743 Torque Converter Clutch Solenoid/Trans Relay Circuits
P0748 Governor Pressure Solenoid Control/Trans Relay Circuits
P0751 Overdrive Switch Pressed (LO) More Than 5 Minutes
P0753 Trans 3-4 Shift Solenoid/Trans Relay Circuits
P0783 3-4 Shift Solenoid, No RPM Drop @ 3-4 Shift
P1195 Catalyst Monitor Slow 02 Sensor (Bank no. 1 Sensor no. 1)
P1197 Catalyst Monitor Slow 02 Sensor (Bank no. 1 Sensor no. 2)
P1281 Engine is Cold Too Long
P1282 Fuel Pump Relay Control Circuit
P1294 Target Idle Not Reached
P1296 No 5 Volts To MAP Sensor
P1297 No Change In MAP From Start To Run
P1388 Auto Shutdown Relay Control Circuit
P1389 No ASD Relay Output Voltage at PCM
P1391 Intermittent Loss of CMP or CKP
P1398 Misfire Adaptive Numerator At Limit or No Crank Sensor Learn
P1486 EVAP Leak Monitor Pinched Hose Or Obstruction Found
P1492 Battery Temp Sensor Voltage Too High
P1493 Battery Temp Sensor Voltage Too Low
P1494 Leak Detection Pump Pressure Switch Or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuits
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1683 Speed Control Power Circuit
P1685 Invalid key received from the Smart Key Immobilizer Module
P1696 PCM Failure EEPROM Write Denied
P1698 PCM Failure EEPROM Write Denied
P1756 Governor Pressure Not Equal To Target @ 15-20 PSI
P1757 Governor Pressure Above 3 PSI In Gear with 0 MPH
P1762 Governor Pressure Sensor Offset Volts Too Low or High
P1763 Governor Pressure Sensor Volts Too High
P1764 Governor Pressure Sensor Volts Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit
P1899 P/N Switch Stuck In Park Or In Gear
