Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Suzuki Tech
Old October 31st, 2007, 12:53 PM   #1
aimmotorsports
aimmotorsports's Avatar
makeing 150-200 hp from a '92 tracker?
i know it can be done, but cost wise is it worth it or just go with a 4.3 swap?
aimmotorsports is offline   Reply With Quote
Old October 31st, 2007, 01:08 PM   #2
Lets do it! Break it down
Out of what motor? If you want 150-200 hp in a tracker motor, then get a 2.5 or 2.7l V6...
Haggar is online now   Reply With Quote
Old October 31st, 2007, 01:30 PM   #3
aimmotorsports
opps! the stock 1.6 8 valve...
i know i can turbo it, but, can swap a 4.3 for about the same price
Old October 31st, 2007, 01:39 PM   #4
95geo
ungrateful douche
95geo's Avatar
dumb idea. expensive. unreliable. still no torque where you need it.
swap the engine.
or better yet! get the rest of the truck capable enough that power is what is holding you back. then when you swap engines you can really tell what your vehicle is capable of.
95geo is offline   Reply With Quote
Old November 1st, 2007, 08:00 PM   #5
aimmotorsports
have 37" ssr's and 3/4 ton 10/ 14 bolt combo in the process...
Old November 1st, 2007, 09:22 PM   #6
jimmyroyse
jimmyroyse's Avatar
150-200 hp = lots of $$$ from a 1.6 8valve.
about all I can offer is look here;
http://www.teamswift.net/
check out www.samuraiguy.com too
jimmyroyse is offline   Reply With Quote
Old November 1st, 2007, 09:32 PM   #7
booblinker
Wrecking a Focus is Cool
booblinker's Avatar
Send a message via AIM to booblinker
vortech 4.3 s/c
NarrowTrail4X4
-2007 Ninja 500
-1993 Ford Ranger 4x4
-1991 CR250
-1989 FS Bronco
-1984 ATC200x
booblinker is online now   Reply With Quote
Old November 2nd, 2007, 06:42 AM   #8
95geo
ungrateful douche
95geo's Avatar
on leaf springs? 200hp, 37s and a 10 bolt with stock shafts will break, if you put alloy shafts in it you already paid to upgrade to a 60 without any room to grow. you can however get away with it if you dont wheel that hard.....
Originally Posted by booblinker View Post
vortech 4.3 s/c
by the time you fork out the 3k for a blower (roots/screw or centrifical?) and the 2 grand for a reliable vortec you could have had just about any other engine out there. packaging would be a serious issue too.
if you're set on supercharged; a 3800 with some tweeks to a 904 to a d300 or whatever would be the way to go. if not supercharged go for the most power for the least amount of weight in the smallest package.
if money doesnt matter the perfect engine for a tracker would be probably the 2008 cts 3.6L with direct injection and VVT...... 300hp with lots of torque all over
Old November 4th, 2007, 11:30 AM   #9
aimmotorsports
is there a tranny that will work with this motor? i have acess to a whole car cheap...
Old November 5th, 2007, 06:51 PM   #10
95geo
ungrateful douche
95geo's Avatar
that would be between the series of numbers between the "3800" and "d300"
Originally Posted by 95geo View Post
....a 3800 with some tweeks to a 904 to a d300....
its a trans that is most commonly found behind the cherokees that had the gm 2.8L 60 degree v6. I believe there are a few 700r4's out there that had a 60 degree pattern but they were 2wd if i remember correctly.
im sure someone with more knowledge on the subject can point you to exactly what you need.
Old November 6th, 2007, 10:34 PM   #11
suepahfly
professional webwheeler
suepahfly's Avatar
Here's some tech on the 60 degree v6
click me
suepahfly is offline   Reply With Quote
Old November 7th, 2007, 04:01 PM   #12
booblinker
booblinker's Avatar
Or a super couple 3.8 with a t5 behind it. I think someone has one for sale on here(not me)
NarrowTrail4X4
-2007 Ninja 500
-1991 CR250
-1989 FS Bronco
-1984 ATC200x
Old November 8th, 2007, 05:14 PM   #13
aimmotorsports
thanks looking more into it now...
Old November 9th, 2007, 12:08 PM   #14
fsumotorhead
뒤죽박죽이다
fsumotorhead's Avatar
I have a 4.3 Vortec you could buy...
http://www.greatlakes4x4.com/showthread.php?t=56783
fsumotorhead is offline   Reply With Quote
Page generated in 0.23954 seconds with 41 queries
