Go Back   Great Lakes 4x4 > General > Yogi's Pig Gig 2008 > Pig Gig Archive 2007
Old September 7th, 2007, 03:33 PM   #1
muddy maki
bad speller deal wid it
muddy maki's Avatar
Send a message via AIM to muddy maki
what is left to fix on your rig?
what do you have left to do to your rig?
ive been working on the rig all week after class but i still have more piddely stuff. i should get it all done though.
have fixed / worked on
break lights (electrical nightmare)
removed flairs and sent to paint
tie rod end replaced
still have to finish
front drive shaft U joints
fix CB
install flairs
have bumper fixed
install lower dash
and last but not least renew my plates and get an orv sticker
muddy maki is offline
Old September 7th, 2007, 03:47 PM   #2
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
build rear driveshaft
build cage
build some kind of tunnel
build new shifters
build steeringshaft/column
run brake lines
run fuel lines
wire jeep
mount propane tank
mount seats
finish trans mount
finish brake mounts
finish exterior tube work
so like maybe 20 minutes of work?
nixxerRsixxer is offline
Old September 7th, 2007, 04:20 PM   #3
Tombs
build cage
build new shifters
run brake lines
run fuel lines
wire jeep
mount propane tank
mount seats
finish trans mount
finish brake mounts
yep,me 2, and then some.
Tombs is offline
Old September 7th, 2007, 04:30 PM   #4
whatutalkinboutwillis
slackers..........
i got mine plated, insured today
and need to
install one shock, build the bracket for it on the axle
alignment
towhooks
and a few minor interior things
CHEAPTHRILLSOFFROAD.COM
Originally Posted by two_much_talk View Post
Ohhhh I can't wait to see the Cheap Thrills guys wheel next to a bunch of lego jeeps !!!
CheapThrillB2 is offline
Old September 7th, 2007, 05:12 PM   #5
nixxerRsixxer
Homewrecker
trust me i left alot out.. im pulling rear drivers shaft right now to replace stupid spring in the seal :/
Old September 7th, 2007, 05:36 PM   #6
redmud
Don't Drink The Kool-Aid
redmud's Avatar
Install overhauled front axle (thanks to jeeperz creeperz!)
Install 4 shocks
coil spacers front and maybe rear
rear brakes
rear LCAs
Test wheel it at the Mounds tomorrow or sunday, make sure I didn't gently caress anything up while putting my Frankenlift together.
redmud is offline
Old September 7th, 2007, 05:40 PM   #7
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
CKUPQ
Need to work on:
Upgrade wiring for 100W highbeams
find/install CB
find/install CB antenna
Tune said CB antenna
Fix center console (in progress)
SquirrelWJ
Need to work on
Find DW problem and fix it Done
Make bar pinsDone
Install front shocksDone
Test out TiresDone
ckupq is offline
Old September 7th, 2007, 06:09 PM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
Send a message via AIM to Pre4runner
Cut off old LCA mounts
Add bump stops
Make trail worthy steering
Oil change
Diff fluid change... new gears just hit 500 miles
'99 XJ LA on 36's winched and locked
My build
Pre4runner is offline
Old September 7th, 2007, 07:38 PM   #9
CHEROKEE666
The Purple Demon
CHEROKEE666's Avatar
Replace a rear leaf spring bushing and change oil and filter.....
CHEROKEE666 is offline
Old September 7th, 2007, 08:30 PM   #10
mikecraneguy
CRANES ARE COOL
mikecraneguy's Avatar
Post
Finish CB install. Find /fix leak in front arb line. . . . . . . . . . . . . tell wife I am going to pig gig, get second set of keys incase that does not go over well
mikecraneguy is offline
Old September 7th, 2007, 08:35 PM   #11
Monster4.0
Monster4.0's Avatar
Send a message via Yahoo to Monster4.0
Add gas.
Add kill switch to the winch. I'm not real fond of 12 volts running to the front bumper at all times.
Speedo and dashlights would be nice, but it's a runner.
YJ pimpin'
Monster4.0 is offline
Old September 7th, 2007, 08:54 PM   #12
brewmenn
The Lumberjack
brewmenn's Avatar
figure out and fix engine knocking
figure out and fix deathwobble
not looking good right now.
brewmenn is online now
Old September 8th, 2007, 06:39 AM   #13
Strangler
Strangler's Avatar
Set rear pinion angle and weld perches
Add rear shock mounts
Build both driveshafts
Build trans and t-case shift linkage
Run brakelines
Run tranny cooler lines
Install cooling fan
Install steering box
Build draglink
Finish cage and seat mounts
Install harness'
Build exhaust
Sort out wiring so that it runs
So, asside from it not running, steering, stopping or offering a place for me to sit I'm practically ready to go.
Strangler is offline
Old September 8th, 2007, 08:22 AM   #14
Pre4runner
Bike Dude
Pre4runner's Avatar
Nice
My build
Old September 8th, 2007, 09:36 AM   #15
Trail Junkie
Ready for winter wheeling
Trail Junkie's Avatar
Careful, I told my wife I was going and now she is too
Trail Junkie is offline
Old September 8th, 2007, 09:39 AM   #16
StartingLine
StartingLine's Avatar
Fix a squeak, fill diffs up due to leaky pinion seals that i'm too lazy to fix right now.
Originally Posted by ouchman View Post
everytime he touches the keyboard, stupid comes out
Originally Posted by bogginboy View Post
mother fucker i havet stole shit from anybody.
StartingLine is offline
Old September 8th, 2007, 11:06 AM   #17
Quagmire
WHAT YOU CRAVE!!!!!!!!!!!
Quagmire's Avatar
Send a message via Yahoo to Quagmire
mount the studs for my disco's
change fluids
regear and lock it
Quagmire is offline
Old September 8th, 2007, 04:58 PM   #18
BRUSER
BRUSER's Avatar
Hopfully replace the broken right front spring ( if black diamond gets on here on time).
BRUSER is offline
Old September 8th, 2007, 05:49 PM   #19
redmud
redmud's Avatar
It took me 6 hours to get my front axle out. I broke both cam bolts, A currie tie rod end, my middle finger on my left hand, and both UCA bolts. I have the smallest list on here, too!
well, okay, my finger's not broken, but it sure hurts like hell.
redmud is offline
Old September 8th, 2007, 06:52 PM   #20
farm_boy
hicktown
farm_boy's Avatar
fisned my7 u jionts and ble b backs is all i have to do no one is comeing with me so should be fun but i need to tell prenets holfully i'm still going after mom finds out
farm_boy is offline
Copyright ©2005 -
