Old August 27th, 2007, 11:44 AM   #1
TopHeavy
Yikes!
TopHeavy's Avatar
Dumb transfer case question
OK, I am a Jeep guy. Let's just get that out of the way first. Anyway, here is my dumb question: Is it true that a Sami transfer case is "divorced"?
NOBAMA
TopHeavy is offline   Reply With Quote
Old August 27th, 2007, 11:45 AM   #2
jeeptjpaul
jeeptjpaul's Avatar
I think so. That just means that there is a driveshaft between the trans and the t case.
jeeptjpaul is offline   Reply With Quote
Old August 27th, 2007, 11:50 AM   #3
TopHeavy
Yikes!
TopHeavy's Avatar
I know what it means.:miff: I was just curious if they really are divorced.
NOBAMA
Old August 27th, 2007, 03:16 PM   #4
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
you are correct sir
90 tracker w/ 3"lift on 31s
99tj sport 3" lift on 33s with a winch
and JPfab. rockrails
suport the sport- www.GLFWDA.org - member
What Lies Beyond Jeep Club of Michigan - member
Originally Posted by a.j. hall View Post
Karmas a bitc*
ouchman is offline   Reply With Quote
Old August 27th, 2007, 05:23 PM   #5
samuraijunkie
Remeber this?
samuraijunkie's Avatar
yep and good thing too
samuraijunkie is offline   Reply With Quote
Old August 27th, 2007, 05:34 PM   #6
mudd_jumper
mudd_jumper's Avatar
how much is the alimony?
mudd_jumper is offline   Reply With Quote
Old August 27th, 2007, 09:03 PM   #7
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Yes they are divored and the power is run to what would normally be the front output. The front and rear driveshafts are perfectly inline.
Old August 28th, 2007, 07:25 AM   #8
TopHeavy
Yikes!
TopHeavy's Avatar
Good info. Next question: Is it a clockwise or counterclockwise input when looking from the front?
NOBAMA
Old August 28th, 2007, 03:02 PM   #9
swampjeep
Swamp Stomper
swampjeep's Avatar
I'm not 100% sure, but I believe it is clockwise, like most vehicles, so you could actually hook up most 2wd engine/transmissions to this t-case.
I've seen a few mazda rotary engines, and they used the mazda trasmission to I believe...
Hallowheeling weekend
clicky here
Old August 28th, 2007, 03:43 PM   #10
Yeah, thats the standard route, to use a 2wd transmission to swap other engines in there. You just make a teeny little driveshaft between them.
Old August 28th, 2007, 03:54 PM   #11
TopHeavy
Yikes!
TopHeavy's Avatar
I am thinking more along the lines of an ATV engine.:tonka:
Thanks for the info.
NOBAMA
Old August 28th, 2007, 04:03 PM   #12
Was thinking thats where you were heading...
Old August 28th, 2007, 10:09 PM   #13
scottie
867-5309
scottie's Avatar
even 2wd samurai's have a "t-case" there
Old August 29th, 2007, 05:16 PM   #14
samuraijunkie
Remeber this?
yep, and the out put shaft is blocked off. I don't know if you can make a 2wd case into a 4x4 case probley not.
Old August 29th, 2007, 05:27 PM   #15
samurai2240
samurai2240's Avatar
SURE YOU CAN, SAME CASE, JUST NEED SOME EXTRA PARTS OFF BROKEN
4X4 T CASE
samurai2240 is offline   Reply With Quote
Page generated in 0.54690 seconds with 43 queries
