Originally Posted by user name
I have a 93 ram with a bad trans. I want to put the magnum 318 in my 88 that has a very tired motor and cant seem to get a clear answer on if the 727 will mount to the magnum without ckp interferance. Anyone do this or know someone that has?
ckp?
The bell housings should be the same as well as mounting points from the flex plate/torque converter. As far as being a direct replacement, not a chance. The computer from the 93 won't work the trans and the computer from the 88 won't work the motor. Of course I'm assuming your 88 is a T.B.I. 318 w/overdrive. Your 93 would be a M.P.I. 318. As far as will they bolt together yes but after that
