Old November 9th, 2005, 12:45 PM   #1
TJ doors in a YJ ??
Will TJ doors work on a YJ with a YJ top ??
Old November 9th, 2005, 01:06 PM   #2
fastrt6dakota
Proud GLFWDA Member
fastrt6dakota's Avatar
Depends, soft or hard top? Soft top? No ah ah. The corners of the doors are square on YJ doors (and the top matches).
Hard top? Not sure. For some reason, I think the doors are different, but I could be wrong.
fastrt6dakota is offline   Reply With Quote
Old November 9th, 2005, 01:24 PM   #3
ogerdgonz
ogerdgonz's Avatar
Actually depends on half doors or full doors. The TJ doors are the same as the YJ from the belt line down. Actually has several parts that say CJ in the description. The problem is the windshields are different between the two so if you use TJ full doors you would have to cut off the portion around the glass and get that part from a YJ. So you would be better off using YJ doors.
Half doors should work with out a problem and then you could use YJ uppers with the rounded corners or get fiberglass uppers.
ogerdgonz is offline   Reply With Quote
Old November 9th, 2005, 02:01 PM   #4
Tonka
tire plug kit use #2
Tonka's Avatar
no, tj doors will not work, the latch mechanism's are different, as are the windshield frame angles.
you could probably make them work, but it would be far easier, and likely cost less to put cj7/cj-8 or yj doors on
Old November 9th, 2005, 02:42 PM   #5
GreaseMonkey
Mmm...turbo...
GreaseMonkey's Avatar
x2
Old November 9th, 2005, 02:54 PM   #6
ok.. the reason i ask is YJ hard doors seem to have the mirror almost half way back on the door and Tj's have a little farther forward.. when theyre back farther they're harder to see out of IMO
Old November 9th, 2005, 03:09 PM   #7
Tonka
Tonka's Avatar
relocate the arm of the mirror to point forward instead of back. they are supposed to fold, but the aluminum corrodes, and may take some persuasion
Old November 9th, 2005, 04:28 PM   #8
Pongking23
CHOP'S Idol
Pongking23's Avatar
Send a message via AIM to Pongking23
cronk, you can make anything fit with an angle grinder.....or a torch!!!!
Pongking23 is offline   Reply With Quote
Old November 9th, 2005, 04:36 PM   #9
ogerdgonz
ogerdgonz's Avatar
Do you mean the little rally mirrors like on the YJ Sahara or laredos that is mounted by the wing window or do you mean the larger mirror mounted on the hinge?
If it is the larger mirror they are exactly the same I have a TJ mirror on my 88 YJ half doors.
Old November 9th, 2005, 04:49 PM   #10
Pongking23
CHOP'S Idol
Pongking23's Avatar
First buy a YJ and then worry about little $*** like the mirrors..............
Old November 9th, 2005, 10:02 PM   #11
u forgot to mention welder..
Page generated in 0.17140 seconds with 35 queries
