Originally Posted by thrca
Sorry if this is a total n00b question, but I'd rather get the details then order crap I don't want.
I am looking to replace the gears on my 98 TJ 4.0 and considering lockers at the same time, so this brought me to a couple questions, which are likely to open a HUGE debate.
1) With 33' ProComp Xterrains, what would be the proper gears to go to in order to get my Jeep back into its power band? I was thinking that 4.10 gears would be about right, but maybe 4.56...
2) If I were going to install lockers, would it be better to do it at the same time as the gears, keeping in mind my budget is typically spread out?
3) What lockers? I am pretty sure I would prefer to go with either a cable locker or a full locker as opposed to an air locker, but not sure what the pros and cons of each other.
4) What budgetary ranges would any different options put me into? I have some money to put in this, but am not looking to spend my kids college tuition on my Jeep.
My current off-road habits are casual off-roader/weekend warrior and this Jeep is my daily driver (although I dont drive much) so I need something that won't force my Jeep into an "Offroad primary, main road occasional" class.
Any help appreciated.
Given the above:
1) 4.10 gears. Since it's the occasional off-roader we'll make it highway happy.
2) Definitely better to install lockers at the same time if you're going to do it. Pay for it once, not twice. Also, depending on your stock gear ratio you may have to buy new carriers to support the new gear ratios. You would then replace them with the lockers (unless doing a lock-right style) and it would be money wasted.
3) That choice is up to you. Lunchbox lockers are very affordable and work well. If you have a Dana 35, you'll probably break it so you may want to consider upgrading it (although it's like polishing a turd). Detroits work but have some quirks that you'll get used to. Selectables (air or electric) are also nice.
4) Gears with full lockers are probably going to run you around $1500 (+/- depending on which lockers). Then there is installation on top of that. I'd say by the time you're all finished, you'll be in the $1700-$2000 range (again +/- depending on what exactly is done).
