Old November 8th, 2005, 05:59 PM   #1
Skooter_Built
Mutha F'n Lead Farmer
Skooter_Built's Avatar
Winch knowlegde
Hi everyone, today i finally bought a winch, brand new Warn 9.5si MOSFET. This will be the first winch ive ever owned/operated and im looking for some info on how to use it safely. What about batterys, should i upgrade to an optima or something similar or go with a dual battery setup? Any info that others can give would help me out a lot.
I'm the man in White.
If you want peace, prepare for war!
Originally Posted by kruzty133 View Post
lol they are all young with low miles and all seals are tight and no leaks. as far as trail ready as you can see the cowboy hat should be a dead give away!! ;()
Skooter_Built is online now   Reply With Quote
Old November 8th, 2005, 06:52 PM   #2
brimy311
Stan has...
brimy311's Avatar
never hook up a winch to the side posts on a battery. They are not rated for the output the winch pulls.
Can't go wrong with an optima.
Old November 8th, 2005, 08:10 PM   #3
Tonka
tire plug kit use #2
Tonka's Avatar
go optima
red top is fine, so is yellow
yellow is a bit better, but I had no issues with my red top and used my winch alot
I ran a 200 amp mean green alternator, and had no issues with a single red top.
Old November 8th, 2005, 09:06 PM   #4
Nrth
trolling
Nrth's Avatar
Heres a good write up at pirate, has a lot of good info.
http://www.pirate4x4.com/tech/billav...ery/index.html
Nrth is offline   Reply With Quote
Old November 8th, 2005, 09:23 PM   #5
wildpig
DONUT LOVER
wildpig's Avatar
call WARN direct and they will send you a "tips and tricks" book, I think it's free if they still send them.
wildpig is offline   Reply With Quote
Old November 8th, 2005, 11:19 PM   #6
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I've heard this before, but have seen it done many times. Any people using that way for years with no problems....so I'm still confused by it.
Old November 8th, 2005, 11:20 PM   #7
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
nothing to be confused about.. the internal wiring of the optima does not support side posts to be used for winching.. its on optimas website.. the people using it for years.. are just not well informed..
nixxerRsixxer is online now   Reply With Quote
Old November 9th, 2005, 07:59 AM   #8
Sonicjay
Back in black
Sonicjay's Avatar
The side posts cascade down from the top posts. I have a Yellow top, and added side posts to it which all the stuff on the Jeep runs off, and the winch by itself is on the top posts.
Skooter, a few of us went to a Warn rebuilding seminar a few months ago, and I have the contact for the guy from Warn. We were planning on setting up a winching techniques seminar for later in the summer, but it hasn't happened yet.
Anyhow, read this:
Sonicjay is offline   Reply With Quote
Old November 9th, 2005, 06:00 PM   #9
Skooter_Built
ok that was a good source of knowledge, but now i have a new question. Beside the winch, d-rings, and a good tow strap, what other winching accessories/tools should i get. Would it make since to go out an buy an accessory kit like Warn sells, or piece one together my self?
Old November 9th, 2005, 06:12 PM   #10
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
From what I was seeing, putting it together yourself works out better since you get what you want.
Ive got some links at home to add later, but for now:
Gloves
D-rings (2+)
Choker Chain
Tree saver Strap
Blanket/Rug/Similar to put over winch cable during operation
Snatch / Pulley block
A convenient bag to store all that in
And be mindful of the ratings on everything you buy. If it doesnt have a rating, pass on it for another product that does. Shop for recovery grade equipment rather than hoisting / overhead lifting rated equipment.
Narrowtrail4x4
Offroader - S10 blazer frame, S10 single cab, Caddy Big Block......
Wintermobile - 96 Jimmy 4.3 / 5spd / 4wd
Blizazer - 00 Blazer 4.3SC/ 6spd / 2wd
Lemons Racecar - 92 Olds Achieva SCX Quad4 W41/Getrag 5 speed
blizazer is offline   Reply With Quote
Old November 9th, 2005, 09:24 PM   #11
blizazer
blizazer's Avatar
Here's some links as promised:
http://offroadrecovery.zoovy.com/cat...theweekestlink
http://www.recoverygear.com/hardware.html
http://www.4x4wire.com/tech/minutemods/chain/
In case anyone else is looking for hydraulic winch links:
http://winchesplus.com/winchmate.htm
http://7slotgrille.com/projects/03rubicon/mm/index.html
http://www.off-road.com/dodge/tech/mmkrec.html
Narrowtrail4x4
Old November 9th, 2005, 10:24 PM   #12
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
but see this helps with my confusion. I know people who have had thier winch hooked up to the side post for at least 5 years, using thier winches alot....I mean alot. And still running the same batteries, nothing bad has happened...
Old November 9th, 2005, 10:24 PM   #13
Sonicjay
Back in black
Sonicjay's Avatar
Gloves
D-rings (2+)
Choker Chain
Tree saver Strap
Most of that comes in the Warn kit that I got. You can never have too many snatch blocks (along with tree savers and shackles to anchor them). each snatch block doubles the winching power (or cuts the winch's effort in half, however you look at it).
Old November 9th, 2005, 10:52 PM   #14
blizazer
blizazer's Avatar
Its not worth risking. Considering that you can walk into any car audio shop and have a dozen high current heavy gauge wire distribution blocks to choose from.
From the information that I'm seeing, the Optima side posts aren't rated for drawing the full battery current over any lengthy time duration, only for short duration high power events, such as cold cranking. What you're likely to see is heat buildup due to IR losses along the conductive path from the top post to the side post. This will lead to one of two things. First, you could possibly melt through insulation internal to the battery and short a pair or string of cells together. This would usualy result in fire. The second likely option would be hydrogen buildup and ignition from the heat. You dont want that either.
So as mentioned above. Its not worth risking. Maybe you can get away with it once, maybe 5 years. But if you blow a hole in your fiberglass hood and fender over $20 in cables you didnt buy, you're going to feel pretty dumb. Or worse if youre standing next to it with the hood up while winching....
Narrowtrail4x4
Old November 9th, 2005, 11:38 PM   #15
lets put it this way Mike. It does work... But the metal the comes down from the top post is 1/8" plate and heats up under HARSH loads. More often then not leading to it melting away. I also know and warned people of this. They too are lucky to have gotten away with it. Call it luck if you will, or just haven't put a strong enough load on it for a long period of time to have this issue.
Old November 10th, 2005, 07:04 AM   #16
C.K.
Dont Feed the Cyco
C.K.'s Avatar
That is one of the best things I have added to my recovery kit over the years.
C.K. is offline   Reply With Quote
Old November 10th, 2005, 08:43 AM   #17
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
For the record guys, I have always had my Warn winch hooked to the top post on my Optima, because I was told to. I just never totally understood why, and have seen people use the side post. Thats the only reason I was asking. Thanks for the info tho'
Another question...are snatch blocks still safe to use with synth cable? The wont snag or tear at it will they? Sorry if that is a stupid ?
Old November 10th, 2005, 08:59 AM   #18
blizazer
blizazer's Avatar
Thats a real good question.
Another item that some people recommend is a spare winch cable, after all, the winch is useless with a broken one.
Ive been thinking about getting a synthetic cable eventually for the winch, and then keeping the steel cable as a spare on hand.
Narrowtrail4x4
Old November 10th, 2005, 11:54 AM   #19
Skooter_Built
so just to clairify, mount the winch power cables to the top of the winch, right?
Old November 10th, 2005, 02:02 PM   #20
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
When switching from metal to synth, make sure you do not have burrs on your fairlead or snatch block. The burrs can snag/cut the line.
I checked out my snatch block for burrs, and since it was clean, have continued using it with synth line with no issues.
I swapped over to an aluminum hawse fairlead from my roller, partially because the rollers were chewed up from the metal line and partially because of hearing about synth rope pinching in roller fairleads.
One thing I've seen with synth line is that it tends to wrap on itself easier than metal winch lines, so be very careful when powering out with it. It's not uncommon for it to quickly change directions when you get to a pinch poinr, and I'd hate to see someone's hand get caught in their winch like the dude in the TV show from a few years ago that they showed on Discovery/TLC in the 4x4 competition.
