$4000 obo
Basics
1993 Cherokee
4.0 HO, AX-15, np231
Front axle:
D44 out of a 79 F250
New ball joints
Dual piston Calipers
Needs short shaft U joint
Rear axle:
FF D60 - 31 spline (somewhere around 30, I don't remember)
Lincoln Locked
Disc brakes
Suspension:
Rear is rough country 4.5" leafs with 1.5" shackle and a 1" block
Front is Clayton 8" hard arm kit with 8" skyjacker coils
Some small stuff it needs:
On 35" bfg A/T's, about 1/4" tread left on rears, 1 front has wear bars poking through. Needs to be aligned. When turning, the tie rod rotates and hits the track bar mount. Rear could use new bushings. T case drop needs to be taken out and cross member welded to the unibody. A few studs. A shorter track bar. An sye, have no vibes until 40, already has a small tail cone so a Go Jeep Sye would be really easy. Finish trimming rear fenders. A new t case linkage (most of it is there, just needs 1 piece). Some body damage. Also missing 2nd upper arm.
Other Stuff:
Gas tank is in the rear because of clearance issues (hole in floor, skid through the floor, gas tank pinched in). Both drivers and passengers side floors have been replaced and whole inside is rhino lined. Wheel base moved back 5" (spring flip). Radio shack CB, CD player, power leather seats in great condition. Removable doors, made the rear drive shaft, electric fan hooked up to wireless remote, ARB snorkel (re routed by me), Custom front bumper with roller fair lead, steering box brace plate (made by me). Push button start ( still need key)
Engine Runs strong, 169,000 miles, tranny shifts smooth and so does t case. Always changed fluids on schedule. Selling it because I see more street than trails. I DD it right now, just made a 400 mile trip from Houghton to Traverse City with no problems (besides drive shaft vibes). Just needs a little work. In Traverse City, MI. Pm me or give me a call - (231) 463-9923
Scott
