Old May 2nd, 2007, 10:59 AM   #1
mikesova
I'm shippin' up to Boston
mikesova's Avatar
Send a message via AIM to mikesova
anybody run longer shackles on a sammy?
I ordered the 2" lift shackles from www.lowrangeoffroad.com, but now i've been looking at some of the things people are saying about the way the sammy will behave on the road and i'm getting a little nervous about it.
anybody here have any thoughts?
I wanted a small/easy/inexpensive lift, so i could put a little bigger tires on it for now.
mikesova is offline   Reply With Quote
Old May 7th, 2007, 10:06 AM   #2
scottie
I have a Dirty Liberty
scottie's Avatar
Do you drive it on the road?
and are you getting shackles that are 2" longer than Stock, or 4" longer than stock?
Old May 7th, 2007, 11:20 AM   #3
The site says 2" lift, which sounds like 4" longer, which sounds like bad news to me.
Old May 7th, 2007, 03:03 PM   #4
mikesova
mikesova's Avatar
yes, they are the 4" longer than stock. I will probably be driving it on the road, it won't be my daily driver, but it's not a dedicated trail rig either.
Old May 7th, 2007, 10:02 PM   #5
Its pretty much a general rule that shackle lifts are about the worst way to lift something.
Adding ~2" or so isn't bad, but 4" is pretty wobbly.
What size tire are you looking to run?
Old May 8th, 2007, 03:53 PM   #6
scottie
scottie's Avatar
Why Not just do a spring over or Shackle Reversal or different Leaf Springs or hammer/Sawzall.
But yes what size of tires are you trying to fit? 4" longer than stock is quite long and it will probably drive kind of crappy, dig into the dirt, and make your springs angry with you.
Old May 10th, 2007, 05:40 AM   #7
mikesova
mikesova's Avatar
i've heard worse things about the shackle reverse...and I didn't want to spring it over because of all the issues that go along with it, but I suppose there are issues with any kind of lift.
Old May 10th, 2007, 05:41 AM   #8
mikesova
mikesova's Avatar
i guess I can fit 235s with them.
Old May 10th, 2007, 12:20 PM   #9
suepahfly
professional webwheeler
suepahfly's Avatar
That much of a shackle lift is , plus its illegal if you drive on the road.
(4) Notwithstanding subsection (2), a person shall not operate a motor vehicle having lift blocks between the front axle and springs, or withlift blocks that exceed 4 inches in height between the rear axle and springs in addition to those provided by the original manufacturer. Any body lift block shall be of single piece construction and shall not use more than a 3-inch spacer. Any suspensionlift block shall use an alignment pin between the axle and the spring, and shall be of single piece construction. Spring shackle replacements shall not exceed the original equipment manufacture length by more than 2 inches, and coil spring spacers are prohibited. All steering components shall be geometrically arranged to function as original equipment manufacture. Welded pitman arms, drag links, and tie rods are prohibited. All parts used to modify the original suspension or height of a motor vehicle shall be factory manufactured and shall meet or exceed the original manufacturer's specifications.
suepahfly is offline   Reply With Quote
Old May 10th, 2007, 12:22 PM   #10
If we followed that law, nobody would have a lifted anything
Old May 10th, 2007, 01:09 PM   #11
suepahfly
suepahfly's Avatar
Yeah I know, I just don't like the idea of super long shackles on the road.
Old May 10th, 2007, 01:19 PM   #12
MrBi11
fac·to·ry /ˈfæktəri, -tri/ [fak-tuh-ree, -tree]
–noun, plural -ries.
1. a building or group of buildings with facilities for the manufacture of goods.
My Garage is a factory, as long as you don't build the lift in your yard that law isn't worth the paper you wiped you ass with
Originally Posted by shift
sometimes I just bend over 'cause it's easier on my knees.
Originally Posted by mmmm nena-j View Post
Looks like it, doesn't it? but nope. Actually the idea it's that you squeeze from the bottom, suck and then swallow the liquid.... Yum!
MrBi11 is offline   Reply With Quote
Old May 10th, 2007, 10:42 PM   #13
mikesova
mikesova's Avatar
i installed them tonight and took it for a drive down the road, the steering was fine and it didn't really act weird. I'm pretty happy with them, except it's obvious that they will catch some stuff on the trails...meh, its a start.
Old May 11th, 2007, 08:19 AM   #14
swampjeep
Swamp Stomper
swampjeep's Avatar
It's a good think you asked for advise before installing them
YOGI'S PIG GIG '08
yes, it's still on this year
Old May 11th, 2007, 12:04 PM   #15
mikesova
mikesova's Avatar
well, i had already ordered them before i had read the cons of them on other boards, so i figured i might as well put em on and see for myself.
Old May 14th, 2007, 09:49 PM   #16
samuraijunkie
Remeber this?
samuraijunkie's Avatar
I run 4" shackels on my blue sammi and it handles fine on the road but i also have a SPOA. Mine dosen't handle too bad on the road but i can't go to fast either with the 31" 15.50s
samuraijunkie is offline   Reply With Quote
Page generated in 0.27957 seconds with 45 queries
