Old April 10th, 2007, 10:42 PM   #1
Brains!
WJ Knuckle swap...
Got the write-up back online
http://www.jcroffroad.com/WJ.html
Old December 2nd, 2007, 07:09 AM   #2
Rocky
DMJC Res A**hole
Rocky's Avatar
Where be the pics? One stupid question can you re ream the knuckles to OTK one ton?
Originally Posted by silverxj View Post
I doubt that porchmonkeys are ever jealous of greasemonkeys.
Old February 8th, 2008, 04:14 PM   #3
Rocky
DMJC Res A**hole
Rocky's Avatar
Incase anyone cares if you do it you'll run into some clearance issues. Like the Tie rod tube hitting on the spring perch, but you can grind it a little to make it work. Also, ES2234R and ES2233L work great for the tie rod if you don't want the long ES2233L to be your weak point. You'll need to run the grease fitting inward since the ES2233L has a larger body than the ES2234R. Other wise the castle nut on the drag link will hit the tie rod.
When you drill the rotors go to 5/8" not 1/2". Atleast I had to since my wheel studs are thicker at the flange.
Old February 9th, 2008, 10:00 PM   #4
Brains!
That looks awesome.
Old February 10th, 2008, 09:08 AM   #5
Rocky
DMJC Res A**hole
Rocky's Avatar
Thanks. Even better is how much clearance you gain with doing it that way.
Old February 10th, 2008, 09:50 AM   #6
Big Daddy Rubicon
(.)(.) Their watching me!
Big Daddy Rubicon's Avatar
Looks good Rocky!
Hey, I'm in a good damn mood!
<---Sometimes 850 HP just is not enough!
Old February 16th, 2008, 10:42 PM   #7
C.K.
Dont Feed the Cyco
C.K.'s Avatar
Originally Posted by Big Daddy Rubicon View Post
Looks good Rocky!
C.K. is offline   Reply With Quote
Page generated in 0.13804 seconds with 27 queries
