Old January 30th, 2006, 01:41 PM   #1
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
Help!!!!!!
will the head off a 94 lsi tracker work on a 90 tracker?
both r 1.6l i used the 90 intake, exhaust manifold,
and cant get it to run, checked the timming several times,
the cam sprocket has 2 marks where the head off the 90
only has 1 any help will be a god sent
...thanx
90 tracker w/ 3"lift on 31s
99tj sport 3" lift on 33s with a winch
and JPfab. rockrails
suport the sport- www.GLFWDA.org - member
What Lies Beyond Jeep Club of Michigan - member
Originally Posted by a.j. hall View Post
Karmas a bitc*
ouchman is offline   Reply With Quote
Old January 30th, 2006, 08:29 PM   #2
scottie
867-5309
scottie's Avatar
...thanx
remove timing belt, rotate crank 180 degrees, its a 2:1 ratio. so there you go.
then hope the pistons don't "interfere" with the valves
there is also a way you could check it by looking at the rotor and knowing when cyl #1 is at TDC if you are 180 degrees off .
Old January 31st, 2006, 09:21 AM   #3
remove #1 spark plug. put your finger over the hole rotate crank til u feel pressure then move to TDC.... (like everyone didnt know that already)
Old January 31st, 2006, 11:59 AM   #4
ouchman
ouchman's Avatar
zook94 called it and saved the day, i'm back mobile
Karmas a bitc*
Old February 1st, 2006, 12:17 PM   #5
zook94
Misfit Extraordinaire
zook94's Avatar
Time of death: 11:24 AM........
zook94 is offline   Reply With Quote
Page generated in 0.10515 seconds with 23 queries
