Formerly 99xjclassic
1987 4runner 31inch tires = bad gas milelage?
I have a 1987 4Runner with the 22RE 4 cylinder engine lifted 2 inches with 31 inch tires. My problem is I get about 13-14 combined mpg. Is this normal? It just seems like it should get a little better. It also has 214,000 miles. Thanks
#2 |
it should be more like high teens to ~20, would be my guess. Maybe a couple less if you have an auto, which does seem to sap power from the 22RE
At 200k+ miles, its probably just tired. Besides loss of compression due to valve and ring wear, you could have a host of other things hurting power: valvetrain out of adjustment camshaft wear clogged exhaust gunk buildup in the intake poor ignition wiring/grounding bad oxygen sensor worn ignition components clogged fuel injectors. I'd look at www.4crawler.com and look at what he did to do tune ups. Thats about as far as I'd go on a 200k mile motor. You could probably get a couple MPG back through routine maintenance.
#4 |
Well, some stuff is free.
Clean the throttle body. Adjust the valves check the plugs and gap them right other stuff is cheap cap and rotor fuel filter air filter etc
#5 |
i have a 22r truck with 31's and gets horriable gas mileage and has under 100k on block and like 70k on head and it still sucks gas down. Its carbed but still i get like 13-15ish and those are diff not a highway truck. anything over 60 just sucks gas twice as bad.
#8 | |
Parts Galore Spokesmodel
my 22re had a RV cam and a header as well. |
#10 |
Bike Dude
Both my 4runner and truck got high teens with 32's.
| Thread Tools | |
| Display Modes | |
