Originally Posted by swampjeep
so MuddyPaws, why do you say he knows not what he speaks of?
First because he has never done any swaps...ever...on anything.
You need to address the steering issues...the box gets replaced and new tie rods and all that. Then there is the brake work that has to be converted. Don't foget about fabbing up the shock mounts and what not...and buying the shocks.
Then you have to adapt the steering lines to fit the new box installed. And adapt the steering shaft to mate to the new box.
Going to have to do something with the driveshafts...even the 3 inch lifts need some kind of spacer or adapter...dunno what it does but you'll have to mod the shafts to work with the new axle flanges.
That's not including finding and buying the sami axles, leafs, u-bolts, and plates. I would guess that if you got a set of axles from a bone yard, they would probably need all new brakes put on them...so more money.
Then the metal you will need to weld in to make the spring mounts and front crossmember. Bolts, nuts, bushings, and shackels.
All the little things that it seems people don't think about when doing something like this. It's not that it can't be done...but simply saying it's cheaper is, IMHO, incorrect. If you were very thrifty, and could wait till the right deal came along for this or that part, then maybe. But that isn't reality for most.
It's sorta like the guys that say it's cheaper to go SOA on a Yj then lift it 4 inches. Not if it's done right, safe and road worthy. Hell, the SYE and driveshaft is almost the cost of a 4 inch kit.
