Go Back   Great Lakes 4x4 > 4x4 Talk > Toyota Tech
Old February 16th, 2007, 11:45 AM   #1
darkteg94
darkteg94's Avatar
Where to get CEL scanned on my p/u?
Can I take it to autozone to have them scan the CEL for a possible code? Wanting to get this fixed now, so I can get the thing running mint. Thinking it's possibly a o2 that's bad. '89 by the way.
darkteg94 is offline   Reply With Quote
Old February 16th, 2007, 12:10 PM   #2
snowscoob
snowscoob's Avatar
Send a message via AIM to snowscoob
I have heard that they will scan your car for free. I have my own scanner and never needed there 'professional' help.
snowscoob is offline   Reply With Quote
Old February 16th, 2007, 01:28 PM   #3
yes, autozone will do it for free
94 Powerstroke, roallin' coal
Old February 16th, 2007, 02:39 PM   #4
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
they will scan it and tell you the code, but they won't clear it and all they tell you is the number they don't know what it means, unless your autozone "professional" has a clue
good luck!!
71jeepster is offline   Reply With Quote
Old February 16th, 2007, 02:49 PM   #5
darkteg94
darkteg94's Avatar
Cool. Didn't know if it was a OBD connection of some sort and if they'd have a scanner for it. I'll get the code this weekend and go from there. Thanks.
Old February 16th, 2007, 03:51 PM   #6
good luck!!
huh? They can clear it with a push of a button, and have done it numerous times for me. They will also tell you what it means, since they want to sell you the parts to fix it. The reader they use displays the code number and explains what the code means on the digital display, so even the dumbest "professional" can sound "car smrt"
Or clear it by unhooking the neg battery cable for 5 min.
Old February 16th, 2007, 03:55 PM   #7
Bratworst
2008 Pig Gig Chairman
Bratworst's Avatar
89' Huh? That narrows it down. If it's a Jeep or Chevy just use the key on & off method. Save on gas! Then research on line for your problem or poss. problem. Or search here for great first class advice
Bratworst is offline   Reply With Quote
Old February 16th, 2007, 06:12 PM   #8
seeing as how this is toyota tech section, I'm betting it's a toyota
since the title says p/u, i'm betting its a pickup.
Old February 16th, 2007, 06:28 PM   #9
ron86toy
dents n dings
Send a message via Yahoo to ron86toy
jump like setting the timing w/ key on CEL will flash
2 digit codes with pauses 1.5 sec in between #'s and 2.5 sec in between codes.
I have the list of codes
to clear codes pull the 15 amp EFI fuse for a min or so
ron86toy is offline   Reply With Quote
Old February 17th, 2007, 09:04 AM   #10
darkteg94
darkteg94's Avatar
Still no dice Ron on finding that plug. I'll have to take a pic under the dash by the fuse box.
Old February 17th, 2007, 09:36 AM   #11
ron86toy
dents n dings
there will not be anything underdaash...unless you pull the efi fuse to reset the puter
should be a small box underhood next to the fuse box(p. side rear of box)thats the diognostic connecter.there are about 15 or so terminals in it,the one marked E1 and T are the one you have to jump
ooE1 o oo
oTo o oo
ooo o oo
the term. kinda looks like that(best way I could think of showing you)
Old March 16th, 2007, 08:20 AM   #12
darkteg94
darkteg94's Avatar
So, I found codes 21 and 42 on my truck. I also located this website:
http://www.off-road.com/toyota/tech/codes/
Tells me I have a bad O2 sensor and speed sensor. Wanted to know if anyone had an idea on fixing these. I'm going to replace the O2 sensor in hopes that it's just bad itself.
Old March 16th, 2007, 08:39 PM   #13
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
does the speedometer work in that thing? i am sure the o2 is bad in that thing. if it is a 1 wire u can use a honda 1 wire 1. just take the bulb out lol
hman1991 is online now   Reply With Quote
Old March 16th, 2007, 08:41 PM   #14
Rattler
Not All There
Rattler's Avatar
Well those O2 sensors are over $100. I think I paid $125 for one for my old '89. There is a cheap trick for them I found out after buying one. If you can pull the O2 sensor out, burn all the crap off it with a propane torch. They are usually just full of carbon and stuff. I learned about this from a guy at a Toyota dealership. They are usually a bitchey-bitch to get out though.
No idea on the speed sensor bit though.
Rattler is offline   Reply With Quote
Old March 25th, 2007, 10:32 PM   #15
tracker
tracker's Avatar
toyota doesn't used the screw in type O2 sensor ...they have the 2 studs mounting flages . tried clearing the codes you have now and run to see what other code is left.. good luck
tracker is offline   Reply With Quote
Page generated in 0.23301 seconds with 43 queries
