Fawkin' Noobs
Front d44 disc brake conversion
Going to swap in a hp d44 out of a 73 f100, planning on doing disc brakes. Are there any good write ups online somewhere? What do you guys suggest I do?
Thanks Scott |
#2 |
I'm on a mission from God
Shouldn't be too hard,
I Believe (now this may be wrong) You need Disc Brake spindles, and backing plates. Then you just need Rotors, caliper and pads. But then again IIRC depending on the exact set-up you may need all new from the knuckle out |
#3 |
Isn't that what you just said? I didn't understand whether you were talking about re-using the drum knuckle or not.
Doing business with "Kennedy" on GL? See this thread for details. Doing business with "Silver Bullet" on GL? He'll leave you Negative Feedback without even doing business with you. See this thread for details. |
#4 |
I love you.
You will need to do some research to see if the inner "C"s are the same as a disc 44...
Then you will need everything from the knuckles out. |
#5 | |
In some cases you dont have to replace the knuckle, you can get away with just replacing the spindle that bolts on to the knuckle. |
#6 |
I love you.
#7 |
Fawkin' Noobs
| Thread Tools | |
| Display Modes | |
