Old December 27th, 2005, 03:42 PM   #1
Icemanii
www.yogispiggig.com
Icemanii's Avatar
Hi-Lift care
Okay, first time I've had a hi-lift mounted on the outside of a vehicle thru the winter. How do you keep it from rusting in this weather and salt?
Ice
Icemanii is offline   Reply With Quote
Old December 27th, 2005, 03:43 PM   #2
take it off
or just keep it cleaned off often, and keep it well soaked with some WD40
Old December 27th, 2005, 05:04 PM   #3
spray off the salt, and make sure to use a good grade grease on the mechinisms.
And don't mount a hi-lift outside the cab. :tonka:
Old December 27th, 2005, 08:36 PM   #4
Icemanii
www.yogispiggig.com
Icemanii's Avatar
Where can you mount one inside a CJ7?? Keep in mind my spoiled rotten son drives it to school daily with a load of friends, so all seats are taken. Doesn't fit behind the seat, so where else is there?
Old December 27th, 2005, 08:46 PM   #5
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
he needs a highlift jack every day? ... perhaps a small bottle jack that fits inside the vehicle is in order .. after all you dont need a highlift to change a tire...
nixxerRsixxer is online now   Reply With Quote
Old December 27th, 2005, 09:10 PM   #6
Icemanii
www.yogispiggig.com
Icemanii's Avatar
Hadn't thought of the bottle jack, but I doubt a small one will do it. The floor jack I have barely lifts the tire off the ground, so not sure if a bottle jack will do it.
Will check into it however, just hate buying more stuff to sit around the garage!
Old December 27th, 2005, 09:29 PM   #7
Grifter
Human Hunter
Grifter's Avatar
I learned the hard way....
i had my hi lift up on my roof rack until the fire acadamy instructor needed one the show proper use and support while using the jaws the other day..took it down and found out that even after a whole bottle of wd40 it was still siezed up...have it inside thawing now...hopefully some 5w30 will help keep it from happening again however i am now working an inside mount for it in my xj..atleast until spring...I also need to invest in a bottel jack to change tires.
..live and learn i guess....
Maier
Grifter is offline   Reply With Quote
Old December 27th, 2005, 09:37 PM   #8
nixxerRsixxer
Homewrecker
you must have like 49" tires or are jacking from an odd location.. even my factory jack could lift my tires several inches when i had 35s on my tj..
Old December 29th, 2005, 07:00 PM   #9
Lothos
KD8GKB
Lothos's Avatar
You don't need JUST a bottle jack. Thats what nice blocks of wood are for. 4x4's work great.
Lothos is online now   Reply With Quote
Old December 29th, 2005, 07:12 PM   #10
Icemanii
www.yogispiggig.com
Icemanii's Avatar
So, I need to carry a bottle jack and blocks of wood to jack up the truck? I need to look under this darn jeep and see how high it sits. I'm thinking a bottle or sissors jack might do it under the axle. Can't be that hard to do.
Old December 29th, 2005, 07:26 PM   #11
Lothos
KD8GKB
Lothos's Avatar
My fav would be jack bags if you can find them cheap. Fits nicely under the seat and some can lift as high as a foot.
Old December 29th, 2005, 07:31 PM   #12
xjjeepthing
Stepped out
xjjeepthing's Avatar
Send a message via Yahoo to xjjeepthing
If you want to mount it outside try on of these . Looks like a good idea.
http://store.summitracing.com/partde...6&autoview=sku
xjjeepthing is offline   Reply With Quote
Old December 29th, 2005, 08:07 PM   #13
xjjeepthing
Stepped out
Just ran across this as well
http://www.jackguard.com/
Any body ever use one or have any info
Old December 31st, 2005, 08:10 AM   #14
I mounted my big 60" high lift on the kicker panel for the back seat. In my old cj
Page generated in 0.19638 seconds with 41 queries
