Old November 3rd, 2006, 01:35 PM   #1
xj4life
Blue XJ Approved
xj4life's Avatar
Ford front D60 and wheel compatability
Sorry for the vague/broad question. Can you run 15" wheels with a front Ford D60?
Old November 3rd, 2006, 01:37 PM   #2
Cooter
私は私の衣服の下で露出している
Cooter's Avatar
Yes
Old November 3rd, 2006, 01:57 PM   #3
99grandtj
I have jeep ADD
99grandtj's Avatar
Send a message via AIM to 99grandtj Send a message via MSN to 99grandtj
Yes, but if you running a 60 that usually means bigger tires which require bigger brakes. Safty first!
98 ljk project
47 Cj2a
?? Bantam TC3
99grandtj is offline   Reply With Quote
Old November 3rd, 2006, 02:00 PM   #4
xj4life
Blue XJ Approved
xj4life's Avatar
i'd probalby only be going from 36's to 38's. My d44/8.8 work great so i cant see needing much more in the way of braking.
Old November 3rd, 2006, 02:26 PM   #5
Usually its accomplished by shaving the caliber, not reducing the rotor size.
Old November 3rd, 2006, 02:58 PM   #6
99grandtj
I have jeep ADD
99grandtj's Avatar
True but you have to run low backspacing 15s.
98 ljk project
47 Cj2a
?? Bantam TC3
Old November 3rd, 2006, 04:46 PM   #7
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I don't know if you can fit 15s on a stock ford d60 with those huge dual piston calipers, but I do know that you can get brackets off ebay and run 3/4t chevy rotors and calipers on a ford d60 and run 15s.
Edit: Some comments from the BV dana 60 article: (quotes he found of people's experiences)
http://www.pirate4x4.com/tech/billav...nt/index2.html
I have Ford Dual Piston calipers and run 15x10 3 inch backspacing with minimal grinding
If you don’t mind running a 2.5 backspacing 15's will fit with little or no grinding on the dual piston calipers
Steel beadlocks 3 inch backspacing and mine fits over 8 lug 92 F350 rotor's and calipers with a little grinding to the outside . When I say "little", I put the wheel on then spun it, heard the rubbing then pulled the wheel and broke out the grinder and shaved a little using a sanding disc to the metal backing of the brake pad that came outside the caliper. 1 min later bolted the wheel back on and spun. No rubbing! Went to the other side and did the same.
'79 Ford RC Dana 60 with 79 Ford dual piston calipers, 2.5"backspacing and very little grinding. Most of the grinding was on the pads and only used a soft wheel on the calipers. About 1/8" space between the wheel and the caliper. No problems thus far with anything getting trapped.
"You cannot fight stupid. You cannot reason with stupid. Stupid does not learn. No matter when you build it, stupid will come." -- Brods
2001 Wrangler & 1975 Wagoneer
Old November 4th, 2006, 02:29 AM   #8
BowtieWrangler
BowtieWrangler's Avatar
just out of curiousity and not trying to argue but why cant someone run 38s on a D44/8.8 combo?
BowtieWrangler is offline   Reply With Quote
Old November 4th, 2006, 10:56 AM   #9
xj4life
Blue XJ Approved
xj4life's Avatar
cause i dont feel like swapping axle shafts and ujoints on the trails. no really i'm sure 90% of the time i could get away with it but i just dont want to take the chance. i'm running 36's on my d44/8.8 and it seems to be working so far.
Old November 24th, 2006, 09:18 AM   #10
NW4x4
Northwest 4x4, Inc.
If you dont want to grind you brakes you will need 2.75" back spacing.
NW4x4 is offline   Reply With Quote
Page generated in 0.21475 seconds with 33 queries
