Anyone Know If The Xj An Tj Share The Same Axle Housing ?? Same Width Ect.?? Ok so TJ's use a low pinion. Here are a few more Questions: Has anyone had any luck at repairing a slightly bent front axle??? (damage is to the short side) The only way I can tell its bent is that the wheel bearing\hub is not flush when bolting it to the knuckle I have to use the bolts to pull the bearing into the knuckle. The welds that hold the tube in the pumpkin leak also. I've put a few thousand miles on it since the damage with no problems. I've been told Clyde's Frame and Wheel in Pontiac can repair it what do you think????? The damage is minimal.
Questions answered, Thanks!
