Old December 21st, 2005, 09:59 PM   #1
Symmes
Location: Grand Rapids/Wyotech blairsville pennsilvania
Send a message via AIM to Symmes
Transfer case problems!!!
Ok we were wheeling, we went up a mound of dirt to flex in my friends 3/4 ton suburban. The transfer case popped out of gear and will not go back in. What could the problems be? It wont go into 4 low or hi, but it sounds like it is trying to engage when you put it into revedrse but it will not go in. Were not shur on what transfer case he has. Its a 94 3/4 ton suburban with the 454 and the 700r4 trans if that helps at all or if these have a know history of breaking?
thanks
jake
Symmes is offline   Reply With Quote
Old December 22nd, 2005, 10:03 AM   #2
bikeworx
bikeworx's Avatar
sounds like the shifter or shift linkage popped out of place
just a thought
bikeworx is offline   Reply With Quote
Old December 22nd, 2005, 07:35 PM   #3
Yankabilly
Check the linkage to the t-case if that is all right and not tweeked. Pull the shift arm off and try to manually put it in 4wd. Do this with the engine NOT running. If it still does not go then I would say you have broken a shift fork inside the t-case.
You say it is a 94- Then you have a 241 t-case and a 4L60E trans not the 700r4.
Old December 22nd, 2005, 09:13 PM   #4
Buy a Jeep save the UAW!
the link on those is just pressed into a plastic one way clip. It could have pulled out and is just laying on top of the T case. the other posibility is the thing gauled the shift ring in the trans and it won't glide on the sycro anymore, I have done lots of those where guys have tried to shift the T case under power. it takes a lot of time and effort to repair.
Old December 23rd, 2005, 11:20 AM   #5
Symmes
Ok thanks guys
Page generated in 0.13102 seconds with 23 queries
