Originally Posted by Jeepinlunatic
the guy who made that write up said he did not know that much about the dodge setups. so i dident take much other then his observation of that year dodge knuckle from what he wrote about it.
Yup i have read that site. That site is why i have the questions to find out if anyone else has just went ahead and used these knuckles before. i have one and it was free, so i figured if i have it is it worth my time and money to mill and drill this knuckle or will i run in to major problems down the road with that thin spot where the brake bracket mounts?
I think that you may have already answered your own question by choosing to describe something on the knucke as a "thin spot".
I referred to the site not because of Dodge-specific information, but so that you can see all the other knuckles and understand what surfaces, geometry, and thicknesses are considered good or bad. Should be easy to make an assessment of the knuckle you have after that.
This was enough of a turn-off for me:
Originally Posted by Mr. N
Dodge late, mid 80's to early 90's. Notice the thin area at the edge of the knuckle where the brakes run. This knuckle has several marginal points, you maybe better finding something else if not running a Dodge.
Dodge early 70's. This is from a 74 Dodge fulltime 4x4, notice the 35 spline stub shaft. Your stuck running the Dodge knuckles-out parts with this knuckle, nothing will interchange.
