October 4th, 2006, 09:17 AM
#3
Lets do it! Break it down
yeah, pretty much what pavement pounder said.
I did this on my 1975 CJ-5.
For me, I got a 1981 CJ-5 parts jeep, and swapped the complete knuckles and axleshafts over to the 1975 Axle. The 1975 axleshafts work, too, but there are some small differences to the dust seal area, so I used the 81s and kept the 75 for spares.
Realistically, thats your best bet, if your axles are good. There are some years you can grab just the brackets and swap them, but they are getting rare, and whole axles are cheap.
Up to sometime in 81, I believe, you have the stronger lock outs. They bolt to the hub with 6 bolts. Later narrow tracks and all wide tracks use the 5 bolt hubs which are weaker.
But, as mentioned, if you don't know, pop the diff open and inspect to make sure the gears are ok first. There might be water in there rusting them up.
